Properties setting
How can I set the values of "node-red-contrib-fs-ops" through the edit change node?
0
2
Click on the node then in the dashboards sidebar, select the help tab. I believe it tells what options you can pass in via the msg object
Looking at your image you just need to set a msg property name, then in a change node prior to the file node, set that msg property to the file name/s.
In a change node you can set something like..
in the file move node, reference those properties
