I added an option list to an existing node to enable selecting an existing property.
The value of the property is saved as string (e.g. "address":"72") to the flow.json instead of "address":72.
Actually I copied the tags of another property and renamed the class and the id. The source property works fine and its selected value is saved as number.
Please advise how I can force the property value to be saved as number to the flow.json.
BR,
Janos
Hi @janoslaszlo
Without seeing exactly what you've done, it's hard to know why it isn't working.
What changes did you make to the nodes html file?
Hi @knolleary,
I changed this:
<div class="form-row">
<label for="node-config-input-address"><i class="fa fa-user"></i> Address</label>
<input type="text" id="node-config-input-address" placeholder="0x48">
</div>
to this:
<label for="node-input-address"><i class="fa fa-address"></i> Address</label>
<select id="node-input-address">
<option value=72 >0x48</option>
<option value=73 >0x49</option>
</select>
</div>
in https://github.com/cinqueon/node-red-contrib-ads1x15/blob/master/ads1x15/ads1x15.html
BR,
Janos
