I'm trying to get values from the typedInput selectBox as integers in my custom node. These values should be linked to binary operations via the config in the js file. But I am not able to get this value in the flow-file as an integer.
I fill the selectboxes in onprepare:
const colourSelOff = {type:'num',types:[{options: [ { value: 0, label: "Off"}, { value: 1, label: "Red"},{ value: 2, label: "Green"}, { value: 3, label: "Blue"}, { value: 4, label: "Orange"}]
$("#node-input-ledOnColor0").typedInput(colourSelOff);
the defaults are defined as follows:
defaults: {
            ledOnColor0: {value:0, validate:RED.validators.number(), required: true},
            ledOffColor0: {value:0, validate:RED.validators.number(), required: true},
            ledOnColor1: {value:0, validate:RED.validators.number(), required: true},
But in the flow file it looks like this:
not changed (default) values integer and those from the typedInput string
        "ledOnColor0": "1",
        "ledOffColor0": "2",
        "ledOnColor1": 0,
        "ledOffColor1": 0,
In the documentation I only ever find examples with string values.
Do you always have to work with strings in html and convert these values in the js file using parseInt, or is there a direct option with this widget ?
Thanks in advance
