I've created my own node, and it's working fine. I do however find it difficult to read data input from my editableList to the correct format. My challenge is:
When reading data that is typed into my editablelist, I get the result in string. I found that the method $("name").editableList('items')[index].find("node-input-elementname").val() provides me with the correct data, but it's as a string.
Is there a different method I can use to get the value in correct format? Is there a method that can provide me with the correct datatype that is used with .typedInput()? If so, I could cast the value before storing the value.
I use some data input fields with string, some with number, and some where's it's possible to choose:
I tried finding the datatype in the jQuery element, but couldn't find anything sensible.
In oneditsave I do the following when pushing data to the node:
var items = $("#node-input-container").editableList('items');
var node = this;
node.props = [];
items.each(function (i) {
var property = $(this);
var r = {
high: property.find(".node-input-engHigh").val(),
low: property.find(".node-input-engLow").val()
node.props.push(r);
When I do send node.props with send({"payload":node.props); in the javascript file, I get high and low in string. I also find these values in string when inspecting the html.
I therefore tried casting the values that are pushed to the node, which worked fine:
var r = {
high: Number(property.find(".node-input-engHigh").val()),
low: Number(property.find(".node-input-engLow").val())
node.props.push(r);
Here's how I generated the html-areas and used .typedInput():
I initially tried different parameters in typedinput, because I didn't get the result I wanted.
