Porting from iot2050 to mraa intel nodes:
- add iot2050 board into pwm, ain, dout
- clean up on close for pwm, ain, dout
- add led into gpio category
Also, maybe it's an offtopic but is it possible to change name of this package from node-red-node-intel-gpio to node-red-node-mraa-gpio?
Is this a potential pull request you have in mind? If so then yes I have no problem with adding the functionality. Renaming is trickier as it would naturally break existing users. ( and I think there is already a contrib nraa node ?) so we don’t want to add confusion.
Yea, I've already the code changes, will do pr then. About renaming - ok, that's true.
