I still fail to get the encoder to work.
I have read the first post. Still no joy.
the solution presented is msg.payload={payload:{....}}
I still get payload:buffer[0] in the debug node
Welcome to the forum @Highlander
Please add a debug node showing what you are sending to the node, expand the contents in the debug pane and paste it here.
Flow...
"id": "d834d19711c19ca1",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": ""
"id": "81b70c550e599623",
"type": "inject",
"z": "d834d19711c19ca1",
"props": [
"p": "payload"
"p": "protobufType",
"v": "Request",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "{\"Request\":{\"has_id\":true,\"id\":35123456123456,\"location_count\":2,\"locations\":[{\"time\":0,\"latitude\":0,\"longitude\":0},{\"time\":10,\"latitude\":0.1,\"longitude\":0.1}]}}",
"payloadType": "json",
"x": 460,
"y": 530,
"a090e55a694af973",
"90277ec091af9456"
"id": "c5f63b690b5d79de",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 880,
"y": 530,
"id": "a090e55a694af973",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 680,
"y": 480,
"id": "90277ec091af9456",
"type": "encode",
"name": "Request",
"protofile": "fe99114ba64e9057",
"protoType": "Request",
"x": 690,
"y": 530,
"c5f63b690b5d79de"
"id": "fe99114ba64e9057",
"type": "protobuf-file",
"protopath": "c:\\Temp\\proto\\test-proto2.proto",
"watchFile": true
test-proto2.proto
syntax = "proto2";
message Request {
// Device's unique id
optional fixed64 id = 1;
repeated Location locations = 200;
message Location {
required int32 time = 1;
required float latitude = 2;
required float longitude = 3;
Thanks !
I have changed the msg.payload.Request to msg.payload
