Publish json data through mqtt
    "w": [
            "tag": "RESET1",
            "value": 0
    "ts": "2017-12-28T12:22:21+0000"
I have to publish this data through mqtt but in this code value is static and I want to make value dynamic.
value tag data will come from numeric input or slider. How i make value dynamic?
Have you tried using variables inside the object, like this?
var variable = "Hello";
var staticValue = "World";
var jsonObject = {
  staticKey: staticValue,
  variableKey: variable
var jsonString = JSON.stringify(jsonObject);
msg.payload = jsonString;
Then publish the jsonString via MQTT.
I tryed this but not working,
var variable =msg.payload;
var staticValue = "Tag1";
var jsonObject = {
return jsonString;
Please try this corrected version. (Sorry - I was typing too fast.)
The issue was the function needs to return an object, not a string.
var variable = msg.payload;
var javascriptObject = {
var jsonString = JSON.stringify(javascriptObject);
Did you manage to try the revised version?
In fact it is not necessary to convert the javascript object to a JSON string before passing to MQTT, the MQTT node will do that for you. So this should work
var jsonObject = {
msg.payload = jsonObject;
Though calling it jsonObject is a misnomer as it is actually a javascript object. It is not JSON, as JSON is a string.
Thanks Colin for pointing out my misnomer - which I have corrected in my listing above.
In the never ending debate function node or not, here using change node and jsonata you can get the same result.
