Pull request proposal: automatic certificate renewal
Paul,
Currently the 'https' has been setup like this:
    https: {
        key: fs.readFileSync('privkey.pem'),
        cert: fs.readFileSync('cert.pem')
As soon as the settings.js file is read by Node-RED, all the code inside will be executed (a.o. the readFileSync functions). From then on the result will be cached (by the 'require' mechanism). This means that the readFileSync will never be executed again afterwards, but you always get the cached old result.
So I 'think' if it originally has been setup as below, that we indeed could have re-read the file (from disc) as often as we wanted:
    https: function() {
        return {
So Nick's proposal to use a separate certificate renewal function makes sense ...
