Hello!
I have Inovelli switches in my home and I'm wanting to run some flows depending on if a certain parameters is set for the switch. I've been looking around and can't figured out how to do it. I've tried using the 'get entities' node and that does not pull the parameters. So, is it possible to pull the parameters of my switch? If so, can someone tell me how? BTW I'm using Home Assistant.
Thank you in advance!!
