Putting the value of a global variable inside a line of an object from inject
Inject node has
"metrics": [
"name": "testing/test1",
"value": 11
"name": "testing/test2",
"value": 12
I then use the JSON node to convert to a string
"{"metrics":[{"name":"testing/test1","value":11},{"name":"testing/test2","value":12}]}"
I have an array of a global variable "Globaltag"
[ "DegreeC", "DegreeF", "Motor1", "Start_PB", "Stop_PB" ]
Now I need to replace the name values such as "testing/test1" with the contents of the global variable Globaltag[0]
How do I specify this in a change node? or is there another way to do this? I try this
change msg.payload
search for testing/test1
replace with global."Global[0]"
result is "{"metrics":[{"name":"undefined","value":11}......
I hope for "{"metrics":[{"name":"DegreeC","value":11}
I can manually use a function node and concat like
var Mystring = '{ "metrics": [ {"name": "' + global.get("Globaltag[0]") + .......
This will eventually get fed to a SparkplugB publish node to go to the broker.
Thank you.
Do not pass through json node as you require it to be a object to alter it .
Then in a change node
Assuming the metrics array is in payload( as you do not specify)
set msg. payload.metrics[0].name
to value of global. Globaltag[0]
If you require it to be a JSON string you can pass it through the JSON node after you have adjusted the properties.
Thank you so very much. Works perfectly. Have a great Holiday season.
