The ArduMower project uses the so called PFOD protocol to communicate via bluetooth and wifi. The ESP8266 provides a TCP Server and I am already able to connect to the TCP Server.
However, I am not able to query the device. I guess, the best would be to describe, how I connect via telnet:
telnet 192.168.5.38 8080
Trying 192.168.5.38...
Connected to 192.168.5.38.
Escape character is '^]'.
{m1}                            <------- this is what I have to send
{=Log sensors}
time,leftsen,rightsen,mowsen,sonleft,soncenter,sonright,perinside,permag,odoleft,odoright,yaw,pitch,roll,gyrox,gyroy,gyroz,accx,accy,accz,comx,comy,comz,hdop,sats,gspeed,gcourse,galt,lat,lon
4804.06,0.00,0.00,0.00,0,0,0,0,32,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,4294967295,255,-1.00,1000.00,1000000.00,1000.00,1000.00
4804.25,0.00,0.00,0.00,0,0,0,0,30,0,0,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,4294967295,255,-1.00,1000.00,1000000.00,1000.00,1000.00
It outputs these lines as long as I send a new command. For some information I have to send say {po} and get a single line.
I created already a TCP client node, but how can I send the commands and receive the lines? I created dummy data with inject and was able to split the lines and forward them to the gui. Only the TCP part is missing. Do you have some hints for me?
Edit: Since I have to query multiple sources for one widget, I guess a solution with a function node may be the right one. Is that right?
