Query from Influxdb
Hi friends. I need your supports.
I'm trying to get data from Influx Cloud DB.
Table influxdb:
I use influxdb in node[v2.0] due to "influxdb cloud".
Contain node like below.
from(bucket: "NodeRed")
|> range(start: -1s)
|> filter(fn: (r) => r["_measurement"] == "myData" and r["_field"] == "Makine" and r["_value"] == "M3")
|> sort(columns: ["_time"], desc: true)
|> limit(n: 1)
But it's not useful. After debugging in nodered, rows containing M2 and M3 are also coming. I want to get only the last row containing the M3 value from Influxdb.
In addition I cannot use below query with influxdb in node[v2.0]. I think v2.0 only works with flux query.
"SELECT *
FROM "myData"
WHERE
("Makine" == 'M3')
order by timestamp desc
limit 1"
1- How can I get contain M3 last row with flux query?
2- Is there alternative using above SQL query in nodered?
Thanks in advance.
I believe that Makine must be a tag (not a field) then you can Group by it to select just the ones you want.
Hi Colin. Thanks for your idea.
The following query solved my problem.
As in SQL, it returns last complete row containing M3.
from(bucket: "NodeRED")
|> range(start: -1m)
|> filter(fn: (r) => r["_measurement"] == "myData")
|> pivot(rowKey: ["_time"], columnKey: ["_field"], valueColumn: "_value")
|> filter(fn:(r) => r.Makine == "M3")
|> limit(n:1)
