Help querying data influxdb with node-red
Hi everyone, I'm learning right now Node-red and influxdb. I have a project in influxdb where I query or read data from a influxdb db. The query I'm doing is the next:
msg.query = 'from(bucket: "sierradata") |> range(start: -1d, stop: now())'
That query is in function and the msg.query message is pass to the influxdb in object from node-red. So that works, it reads 4 objects. The problem is that I'm not reading the values from the measurements of the database. What I'm reading is 4 objects like this:
0: object
result: "_result"
table: 0
_start: "2021-02-09T08:34:43.5651746Z"
_stop: "2021-02-10T08:34:43.5651746Z"
_time: "2021-02-10T08:12:47.857Z"
_value: "sierra"
_field: "type"
_measurement: "datas"
And the datas I'm interested in reading are inside the measurement "datas" and I don't know how to acces or read that data. Those "datas" are:
Time type value
161294... sierra 1
161294... sierra 2
If anyone can help me I'd really appreciate. Thanks in advance!
Welcome to the forum @Rafa.
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
Also I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
