The only issue i see is you are attempting tp put msg.payload
from the mySQL select directly into a chart and a ui text.
If you look at the output of the mySQL node you will see it is an array - a chart expects the value to display to be in msg.payload and the topic to be the name of the series (this is explained in the chart built in help).
Use a change node to move the result into msg.payload and set the topic to a nice name
e.g...
modified flow...
[{"id":"40db8166.c4d","type":"ui_text","z":"28abaa7d.30d2e6","group":"816f6911.01f668","order":1,"width":0,"height":0,"name":"","label":"Object In Field","format":"{{msg.payload}}","layout":"row-left","x":960,"y":560,"wires":[]},{"id":"88e8b41.ced5648","type":"change","z":"28abaa7d.30d2e6","name":"move 1st row value to payload & set topic","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[0].trigger_count","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"CAMERA 2 Trigger Count","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":500,"wires":[["40db8166.c4d","5a96c769.669858","c6165000.6b97e"]]},{"id":"f110b5af.da4cc8","type":"mysql","z":"28abaa7d.30d2e6","mydb":"a8651bd.a83c8e8","name":"","x":540,"y":500,"wires":[["9e5d1a5a.b6ce38","88e8b41.ced5648"]]},{"id":"5a96c769.669858","type":"ui_chart","z":"28abaa7d.30d2e6","name":"","group":"816f6911.01f668","order":0,"width":"10","height":"7","label":"chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"60","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":930,"y":600,"wires":[[]]},{"id":"c6165000.6b97e","type":"debug","z":"28abaa7d.30d2e6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1050,"y":440,"wires":[]},{"id":"ca3b867f.e70db8","type":"function","z":"28abaa7d.30d2e6","name":"","func":"msg.topic = \"SELECT COUNT(*) AS 'trigger_count' FROM bvcddb.objectinfield WHERE ID = '172.27.185.90'\";\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":500,"wires":[["f110b5af.da4cc8"]]},{"id":"9e5d1a5a.b6ce38","type":"debug","z":"28abaa7d.30d2e6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":730,"y":440,"wires":[]},{"id":"ecce8e56.d1347","type":"inject","z":"28abaa7d.30d2e6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"5","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":500,"wires":[["ca3b867f.e70db8"]]},{"id":"816f6911.01f668","type":"ui_group","name":"Camera","tab":"62a9cea8.ba3c5","order":1,"disp":true,"width":"20","collapse":false},{"id":"a8651bd.a83c8e8","type":"MySQLdatabase","name":"","host":"127.0.0.1","port":"3306","db":"bvcddb","tz":"","charset":"UTF8"},{"id":"62a9cea8.ba3c5","type":"ui_tab","name":"Info","icon":"dashboard","disabled":false,"hidden":false}]
PS: this is untested since i dont have your data or database.
