Querying TIMESTAMP column from mySQL table, unexpected result
[{"id":"21713bc1.4cc3b4","type":"tab","label":"my edit to Databse","disabled":false,"info":""},{"id":"43089f40.837d1","type":"inject","z":"21713bc1.4cc3b4","name":"create database table","topic":"CREATE TABLE data(TIMESTAMP INT PRIMARY KEY NOT NULL, SENSOR TEXT NOT NULL, TEMPERATURE INT NOT NULL, HUMIDITY INT NOT NULL)","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":205.0833282470703,"y":137.08334350585938,"wires":[["fac0809e.d434c"]]},{"id":"1ba18632.d0e84a","type":"debug","z":"21713bc1.4cc3b4","name":"database_out","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":876.0833129882812,"y":269.0833740234375,"wires":[]},{"id":"7adebdc0.75faec","type":"inject","z":"21713bc1.4cc3b4","name":"insert data","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":139.0833282470703,"y":382.0833511352539,"wires":[["85c2080e.837828"]]},{"id":"ad76b8a3.459d48","type":"inject","z":"21713bc1.4cc3b4","name":"delete records","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":182.0833282470703,"y":218.0833511352539,"wires":[["c9dad696.1a7438"]]},{"id":"40464f7b.cd1a78","type":"inject","z":"21713bc1.4cc3b4","name":"show RECORDS","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"","x":141.0833282470703,"y":530.0833435058594,"wires":[["9805579b.0455d8"]]},{"id":"3dca9a55.49ff36","type":"inject","z":"21713bc1.4cc3b4","name":"Test Data","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":114.08332824707031,"y":660.0834121704102,"wires":[["5294f53.104b98c"]]},{"id":"1a8f6865.49af7","type":"function","z":"21713bc1.4cc3b4","name":"create test data","func":"var count=context.get('count');\nvar timestamp=context.get('timestamp');\n\nif (count===undefined)\n{\n    count=1;\n    //timestamp=1;\n}\nvar data1={\"sensor\":\"sensor1\",\"temperature\":21,\"humidity\":61};\n//var data2={\"sensor\":\"sensor2\",\"temperature\":22,\"humidity\":62};\n//var data3={\"sensor\":\"sensor3\",\"temperature\":23,\"humidity\":63};\nif (count%20===0)\n    count=-count;\ndata1.temperature+=(count*.25);\n//data2.temperature+=(count*.5);\n//data3.temperature+=(count*.75);\ndata1.humidity+=(count*.25);\n//data2.humidity+=(count*.5);\n//data3.humidity+=(count*.75);\nmsg.payload=[data1];\nvar msg1={};\nvar msg2={};\nvar msg3={};\n\ndata1.timestamp=msg.timestamp;\n//timestamp+=1;\n//data2.timestamp=timestamp;\n//timestamp+=1;\n//data3.timestamp=timestamp;\n\nmsg1.payload=data1;\n//msg2.payload=data2;\n//msg3.payload=data3;\n//timestamp+=1;\ncount+=1;\ncontext.set('count',count);\ncontext.set('timestamp',timestamp);\n\n\nreturn msg1;","outputs":1,"noerr":0,"x":231.0833282470703,"y":715.0834121704102,"wires":[["66733ab6.e3842c","8d024dd.dbca6b"]]},{"id":"66733ab6.e3842c","type":"debug","z":"21713bc1.4cc3b4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":484.08331298828125,"y":717.0833740234375,"wires":[]},{"id":"8d024dd.dbca6b","type":"function","z":"21713bc1.4cc3b4","name":"write query","func":"var timestamp=msg.payload.timestamp;\nvar sensor=msg.payload.sensor;\nvar temperature=msg.payload.temperature;\nvar humidity=msg.payload.humidity;\n//put data into json string\n\nmsg=\"(timestamp,sensor,temperature,humidity) values(\\'\"+timestamp +\"\\',\\'\"+sensor +\"\\',\" + temperature + \",\" + humidity +\")\";\nvar topic=\"INSERT INTO DATA \" +msg;\nvar msg1={};\nmsg1.topic=topic;\nmsg1.payload=timestamp;\nreturn msg1;","outputs":1,"noerr":0,"x":326.08331298828125,"y":667.0833740234375,"wires":[["54fe078.61ffb78","5dcdd59.7920dac"]]},{"id":"54fe078.61ffb78","type":"debug","z":"21713bc1.4cc3b4","name":"sql out","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":508.08331298828125,"y":665.0833435058594,"wires":[]},{"id":"85c2080e.837828","type":"function","z":"21713bc1.4cc3b4","name":"Insert using variable","func":"var sensor=\"sensor5\";\nmsg=\"( timestamp,sensor,temperature,humidity) values(4,\"+\"\\'\"+sensor +\"\\'\" + \",20,66)\";\nvar topic=\"INSERT INTO DATA \" +msg;\nvar msg1={};\nmsg1.topic=topic;\n\nreturn msg1;","outputs":1,"noerr":0,"x":332.08331298828125,"y":380.0833511352539,"wires":[["46459ea6.e60f6","3f3087a5.6a372"]]},{"id":"46459ea6.e60f6","type":"debug","z":"21713bc1.4cc3b4","name":"insert","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":800.0833129882812,"y":373.0833511352539,"wires":[]},{"id":"ac7bd110.0e9b5","type":"inject","z":"21713bc1.4cc3b4","name":"Drop Table data","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"","x":191.0833282470703,"y":305.0833511352539,"wires":[["d5f4d33a.c7bd68"]]},{"id":"75c64efb.b96ae","type":"inject","z":"21713bc1.4cc3b4","name":"insert","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":161.0833282470703,"y":263.0833511352539,"wires":[["88eebeac.354658"]]},{"id":"4e7cb534.77dba4","type":"mysql","z":"21713bc1.4cc3b4","mydb":"13a851ac.267e3e","name":"","x":646.2499389648438,"y":125.75,"wires":[["5868d455.b4c894"]]},{"id":"3f3087a5.6a372","type":"mysql","z":"21713bc1.4cc3b4","mydb":"13a851ac.267e3e","name":"","x":650.1666259765625,"y":266.1666946411133,"wires":[["1ba18632.d0e84a"]]},{"id":"5868d455.b4c894","type":"debug","z":"21713bc1.4cc3b4","name":"insert","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":868.1666259765625,"y":133.16668701171875,"wires":[]},{"id":"88eebeac.354658","type":"sqlstring-format","z":"21713bc1.4cc3b4","name":"insert into data","query":"INSERT INTO data( timestamp,sensor,temperature,humidity)\nvalues(0,'sensor',20,66)","vars":"","outField":"topic","x":413.1666259765625,"y":260.1666946411133,"wires":[["3f3087a5.6a372"]]},{"id":"d5f4d33a.c7bd68","type":"sqlstring-format","z":"21713bc1.4cc3b4","name":"DROP Table data","query":"DROP TABLE data","vars":"","outField":"topic","x":422.16656494140625,"y":301.1666946411133,"wires":[["3f3087a5.6a372"]]},{"id":"a408f4a0.3fc578","type":"catch","z":"21713bc1.4cc3b4","name":"","scope":null,"uncaught":false,"x":91.08332824707031,"y":796.083381652832,"wires":[["acf3628d.6d4fa","316dc356.a69a3c"]]},{"id":"acf3628d.6d4fa","type":"debug","z":"21713bc1.4cc3b4","name":"error","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":232.0833282470703,"y":841.083381652832,"wires":[]},{"id":"9912f1b3.f04b7","type":"ui_text","z":"21713bc1.4cc3b4","group":"9292b504.948de","order":7,"width":0,"height":0,"name":"","label":"text","format":"{{msg.payload}}","layout":"row-spread","x":389.08331298828125,"y":802.083381652832,"wires":[\*]},{"id":"316dc356.a69a3c","type":"function","z":"21713bc1.4cc3b4","name":"sql errors","func":"var payload=msg.error.message;\nmsg.payload = payload +\" timestamp \"+msg.payload;\nreturn msg;","outputs":1,"noerr":0,"x":242.08331298828125,"y":802.083381652832,"wires":[["9912f1b3.f04b7"]]},{"id":"c1a92b53.40ece8","type":"function","z":"21713bc1.4cc3b4","name":"Clear errors","func":"node.error(\"\",msg);//clear error\nreturn msg;","outputs":1,"noerr":0,"x":292.08331298828125,"y":892.083381652832,"wires":[[]]},{"id":"67e139af.63786","type":"inject","z":"21713bc1.4cc3b4","name":"clear errors","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":114.08332824707031,"y":892.0834121704102,"wires":[["c1a92b53.40ece8"]]},{"id":"2ccfae60.38c16a","type":"inject","z":"21713bc1.4cc3b4","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":145.0833282470703,"y":1419.0833435058594,"wires":[["eabf21a9.283dc"]]},{"id":"eabf21a9.283dc","type":"function","z":"21713bc1.4cc3b4","name":"","func":"var data={};\ndata[\"temp\"]=20;\ndata[\"humidity\"]=50;\njson_out=JSON.stringify(data);\nreturn msg;","outputs":1,"noerr":0,"x":315.0833282470703,"y":1459.0833435058594,"wires":[[]]},{"id":"c9dad696.1a7438","type":"sqlstring-format","z":"21713bc1.4cc3b4","name":"delete records","query":"DELETE FROM DATA WHERE count>=0","vars":"","outField":"topic","x":413.08331298828125,"y":216.0833511352539,"wires":[["3f3087a5.6a372","5dcdd59.7920dac"]]},{"id":"fac0809e.d434c","type":"sqlstring-format","z":"21713bc1.4cc3b4","name":"create database table","query":"USE node_red;\nCREATE TABLE data(\n\t\t\tcount MEDIUMINT PRIMARY KEY NOT NULL AUTO_INCREMENT,\n\t\t\tTIMESTAMP TIMESTAMP NOT NULL,\n\t\t\tSENSOR TEXT NOT NULL,\n\t\t\tTEMPERATURE INT NOT NULL,\n\t\t\tHUMIDITY INT NOT NULL);","vars":"","outField":"topic","x":435.08331298828125,"y":129.08334350585938,"wires":[["3f3087a5.6a372"]]},{"id":"774c7446.99e52c","type":"sqlstring-format","z":"21713bc1.4cc3b4","name":"Show records","query":"SELECT * FROM data","vars":"","outField":"topic","x":607.0833129882812,"y":534.0833435058594,"wires":[["5dcdd59.7920dac"]]},{"id":"48ca50a2.b9fe2","type":"inject","z":"21713bc1.4cc3b4","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":770.3666381835938,"y":429,"wires":[["46459ea6.e60f6"]]},{"id":"387c0cbb.019a9c","type":"moment","z":"21713bc1.4cc3b4","name":"Month-DD hh:mm:sss","topic":"","input":"","inputType":"date","inTz":"Africa/Johannesburg","adjAmount":0,"adjType":"days","adjDir":"add","format":"MMM-DD hh:mm:sss","locale":"en_ZA","output":"timestamp","outputType":"msg","outTz":"Africa/Johannesburg","x":443.36663818359375,"y":62.666648864746094,"wires":[["46459ea6.e60f6"]]},{"id":"f3d1e7a9.70cd1","type":"inject","z":"21713bc1.4cc3b4","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":182.3666534423828,"y":58,"wires":[["387c0cbb.019a9c"]]},{"id":"5294f53.104b98c","type":"moment","z":"21713bc1.4cc3b4","name":"YYYY-MM-DD hh:mm:ss","topic":"","input":"","inputType":"date","inTz":"Africa/Johannesburg","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-MM-DD hh:mm:ss","locale":"en_ZA","output":"timestamp","outputType":"msg","outTz":"Africa/Johannesburg","x":221.0833282470703,"y":607.0833435058594,"wires":[["1a8f6865.49af7","c312674a.c6a888"]]},{"id":"c312674a.c6a888","type":"debug","z":"21713bc1.4cc3b4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":483.08331298828125,"y":604.0833435058594,"wires":[]},{"id":"5dcdd59.7920dac","type":"mysql","z":"21713bc1.4cc3b4","mydb":"13a851ac.267e3e","name":"","x":692.0833129882812,"y":677.583251953125,"wires":[["2f7a966f.902e1a","32e4f64.50e570a"]]},{"id":"2f7a966f.902e1a","type":"ui_template","z":"21713bc1.4cc3b4","group":"9292b504.948de","name":"UI Table","order":1,"width":"","height":"","format":"<style>\n.table\n{\n    height:400px;\n    width:1000px;\n    background:lightblue;\n}\n</style>\n<div class=\"table\">\n<table style=\"width:100%\">\n  <tr>\n    <th>count</th> \n    <th>TIMESTAMP</th> \n    <th>SENSOR</th>\n    <th>TEMPERATURE</th> \n    <th>HUMIDITY</th>\n  \n  </tr>\n  <tr ng-repeat=\"x in msg.payload | limitTo:10\">\n    <td>{{msg.payload[$index].count}}</td>\n    <td>{{msg.payload[$index].TIMESTAMP}}</td>\n    <td>{{msg.payload[$index].SENSOR}}</td>\n    <td>{{msg.payload[$index].TEMPERATURE}}</td> \n    <td>{{msg.payload[$index].HUMIDITY}}</td>\n\n  </tr>\n</table>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":899.0833129882812,"y":671.0833129882812,"wires":[["1a54d24e.1c813e"]]},{"id":"32e4f64.50e570a","type":"debug","z":"21713bc1.4cc3b4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":864.0833129882812,"y":733.0833129882812,"wires":[]},{"id":"1a54d24e.1c813e","type":"debug","z":"21713bc1.4cc3b4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1070.0833740234375,"y":671.5833129882812,"wires":[]},{"id":"9805579b.0455d8","type":"moment","z":"21713bc1.4cc3b4","name":"YYYY-MM-DD hh:mm:ss","topic":"","input":"","inputType":"date","inTz":"Africa/Johannesburg","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-MM-DD hh:mm:ss","locale":"en_ZA","output":"timestamp","outputType":"msg","outTz":"Africa/Johannesburg","x":371.08331298828125,"y":525.5833282470703,"wires":[["774c7446.99e52c"]]},{"id":"13a851ac.267e3e","type":"MySQLdatabase","z":"","host":"localhost","port":"3306","db":"node_red","tz":"GMT+2"},{"id":"9292b504.948de","type":"ui_group","z":"","name":"Sensors","tab":"b52510cb.895308","order":1,"disp":true,"width":"12","collapse":false},{"id":"b52510cb.895308","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
high please use code above to follow my flows.
I create timestamps in node-red using the moment node.
I insert these into a TABLE called data using the correct mySQL TIMESTAMP format/syntax and all is well. Although when I query it back from the database is returns the columns in msg.payload array, as it should, but the timestamp in the array is a different time value to what I put in.
in the pink box i use [SELECT * FROM data] to query the data table for all columns. I have circle in pink the timestamp that I am uncertain of where it comes from because in mySQL table it is not stored in this way. refer to next image.
circled in blue is the exact way it is stored in mySQL TIMESTAMP column
flow7
where is the TIMESTAMP: "2020-03-17T07:35:38.000Z"
coming from?
Please take note of the pinned forum topic and repost your flow between triple back-ticks.
The difference in time is likely to be the difference between UTC (Zulu) time and your local time. You should always work with UTC until you are ready to display to users in order to save confusion and timezone/DST errors.
The Z means that this is the time in Zulu or UTC time. Is the 09:35 correct for the local time? If so is your timezone UTC + 2 hours? If yes then the timestamp shown in the debug pane is the same time as the the database query shows (which is being converted to local time for you for display), so everything is good.
Sorry, you have lost me, however if you are trying to write the current time to the database then it is easy, you should should configure the column to use a default value of current time (I forget the exact syntax in mysql) and then it will fill it in for you automatically.
