good day to all of you i am new to node red, i need to create a table into a database that comes from an industrial laundry at a hospital, i need to create cycle start time and cycle finish time, i get errors about parse and format, i request your help about how to convert in a propper maner time
"id": "f72663007f24db2a",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "38b9dfb8b8e6c204",
"type": "mysql",
"z": "f72663007f24db2a",
"mydb": "3e10e97bf1ddab3a",
"name": "hospitalv1",
"x": 540,
"y": 120,
"652cf94177aca208"
"id": "34818c4488d30185",
"type": "ui_button",
"group": "ea5811b1fe9d49fa",
"order": 3,
"width": 0,
"height": 0,
"passthru": false,
"label": "Refresh Data",
"tooltip": "Load Data from Database",
"color": "",
"bgcolor": "",
"className": "",
"icon": "fa-refesh",
"payload": "",
"payloadType": "str",
"topic": "topic",
"topicType": "msg",
"x": 130,
"y": 120,
"d525e13d1410afea"
"id": "d525e13d1410afea",
"type": "function",
"name": "get user values",
"func": "msg.topic = \"SELECT * FROM lavadoras_v0;\";\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 340,
"y": 120,
"38b9dfb8b8e6c204"
"id": "652cf94177aca208",
"type": "debug",
"name": "debug 1",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 720,
"y": 120,
"id": "ec868fdb9498dcd3",
"type": "ui_chart",
"order": 2,
"width": 0,
"height": 0,
"label": "values",
"chartType": "line",
"legend": "true",
"xformat": "HH:mm",
"interpolate": "linear",
"nodata": "No Data Available",
"dot": false,
"ymin": "",
"ymax": "",
"removeOlder": 1,
"removeOlderPoints": "",
"removeOlderUnit": "3600",
"cutout": 0,
"useOneColor": false,
"useUTC": false,
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"outputs": 1,
"useDifferentColor": false,
"className": "",
"x": 710,
"y": 40,
"id": "8727aba6947276e7",
"order": 4,
"width": 0,
"height": 0,
"passthru": false,
"label": "Delete Chart Data",
"tooltip": "Deletes DAta in chart",
"color": "",
"bgcolor": "red",
"className": "",
"icon": "fa-trash",
"payload": "[]",
"payloadType": "json",
"topic": "topic",
"topicType": "msg",
"x": 490,
"y": 40,
"ec868fdb9498dcd3"
"id": "bad182c93fa2585e",
"type": "s7 in",
"endpoint": "0f6966b00b831166",
"mode": "single",
"variable": "Num_Lavadora",
"diff": true,
"name": "Num_lavadora",
"x": 140,
"y": 420,
"0217049624e51832"
"id": "0217049624e51832",
"type": "function",
"name": "flowset_Num_Equipo",
"func": "var Num_Equipo_var;\nflow.set(\"Num_Equipo_var\",msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 420,
"c8f98b5479c3b1d3"
"id": "c8f98b5479c3b1d3",
"type": "debug",
"name": "debug 2",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 420,
"id": "4d8eb2b6a7b68efb",
"type": "s7 in",
"mode": "single",
"variable": "Terminado_Completo",
"diff": true,
"name": "Terminado_Completo",
"x": 160,
"y": 500,
"d3f6899ea944c2bd"
"id": "4c504cb7b08f0b93",
"type": "debug",
"name": "debug 3",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"x": 640,
"y": 500,
"id": "1d74940dcc2064a8",
"type": "s7 in",
"mode": "single",
"variable": "Tipo_Ciclo",
"diff": true,
"name": "Tipo_Ciclo",
"x": 120,
"y": 560,
"1f551a99addbf509"
"id": "93ba046bfe8e19e7",
"type": "debug",
"name": "debug 4",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 560,
"id": "feefa4b5231951ac",
"type": "s7 in",
"mode": "single",
"variable": "Personalizado",
"diff": true,
"name": "Personalizado_Ciclo",
"x": 150,
"y": 620,
"12dea99303d3a02d"
"id": "40f3d356e7c75d81",
"type": "debug",
"name": "debug 5",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 620,
"id": "a228884814c3ba9b",
"type": "s7 in",
"mode": "single",
"variable": "Remojo",
"diff": true,
"name": "remojo",
"x": 110,
"y": 700,
"e15f0ef188fded1a"
"id": "1c46cb177dd5f2cb",
"type": "debug",
"name": "debug 6",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 700,
"id": "33d79ea72418963f",
"type": "s7 in",
"mode": "single",
"variable": "Usuario",
"diff": true,
"name": "usuario",
"x": 110,
"y": 780,
"f33b5e4172140141"
"id": "b0be9a4272c92098",
"type": "debug",
"name": "debug 7",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 780,
"id": "7d5d85e637ecd5e0",
"type": "s7 in",
"mode": "single",
"variable": "Num_Ticket",
"diff": true,
"name": "Num_Ticket",
"x": 130,
"y": 840,
"de99d7be96677caf"
"id": "751f5c90e6d45958",
"type": "debug",
"name": "debug 8",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 840,
"id": "d50ba58e6fee7c39",
"type": "s7 in",
"mode": "single",
"variable": "Hora_inicio",
"diff": true,
"name": "Hora_Inicio",
"x": 130,
"y": 920,
"0155b791cf06515c"
"id": "0155b791cf06515c",
"type": "function",
"name": "start_time",
"func": "var start_time_var;\nflow.set(\"start_time_var\", msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 360,
"y": 920,
"f6d2e6dab64ca9e2"
"id": "f6d2e6dab64ca9e2",
"type": "debug",
"name": "debug 9",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 920,
"id": "f95010dee9efc7c4",
"type": "s7 in",
"mode": "single",
"variable": "Hora_Fin",
"diff": true,
"x": 130,
"y": 1000,
"f69c1d4cc97d7f07"
"id": "f69c1d4cc97d7f07",
"type": "function",
"name": "end_time",
"func": "var end_time_var;\nflow.set(\"end_time_var\", msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 360,
"y": 1000,
"c7632774382a416d"
"id": "c7632774382a416d",
"type": "debug",
"name": "debug 10",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 1000,
"id": "1f551a99addbf509",
"type": "function",
"name": "flow_set_tipo_ciclo",
"func": "var tipo_ciclo_var;\nflow.set(\"tipo_ciclo_var\",msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 390,
"y": 560,
"93ba046bfe8e19e7"
"id": "12dea99303d3a02d",
"type": "function",
"name": "flow_set_personalizado",
"func": "var personalizado_var;\nflow.set(\"personalizado_var\",msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 430,
"y": 620,
"40f3d356e7c75d81"
"id": "d3f6899ea944c2bd",
"type": "function",
"name": "insertar_datos",
"func": "var mensaje;\nmensaje = \"INSERT INTO lavadoras_v0 (Num_lavadora, tipo_ciclo, ciclo_personalizado, remojo, operador, num_ticket, hora_inicio, hora_fin, disponible) \";\nmensaje = mensaje + \"VALUES (\";\nmensaje = mensaje + \"\"+flow.get(\"Num_Equipo_var\")+\",\"+flow.get(\"tipo_ciclo_var\")+\"\";\nmensaje = mensaje + \",\"+flow.get(\"personalizado_var\")+\",\" + flow.get(\"remojo_var\")+\"\";\nmensaje = mensaje + \",\"+flow.get(\"usuario_var\")+\",\"+flow.get(\"ticket_var\")+\"\";\nmensaje = mensaje + \",\"+flow.get(\"start_time_var\")+\",\"+flow.get(\"end_time_var\")+\"\";\nmensaje= mensaje + \",\"+flow.get(\"disponible_var\")+\"\";\nmensaje = mensaje + \")\";\nmsg.topic = mensaje;\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 540,
"y": 280,
"41d3f79cd098efb3",
"38b9dfb8b8e6c204"
"id": "41d3f79cd098efb3",
"type": "debug",
"name": "debug 11",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 760,
"y": 280,
"id": "e15f0ef188fded1a",
"type": "function",
"name": "flow_set_remojo",
"func": "var remojo_var;\nflow.set(\"remojo_var\",msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 360,
"y": 700,
"1c46cb177dd5f2cb"
"id": "f33b5e4172140141",
"type": "function",
"name": "flow_set_usuario",
"func": "var usuario_var;\nflow.set(\"usuario_var\",msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 410,
"y": 780,
"b0be9a4272c92098"
"id": "de99d7be96677caf",
"type": "function",
"name": "flow_set_num_ticket",
"func": "var ticket_var;\nflow.set(\"ticket_var\",msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 400,
"y": 840,
"751f5c90e6d45958"
"id": "a899fde0495c3287",
"type": "s7 in",
"mode": "single",
"variable": "Disonible",
"diff": true,
"name": "disponible",
"x": 120,
"y": 1080,
"42025056566c8238"
"id": "a6f9ad551e15cd75",
"type": "debug",
"name": "debug 12",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 640,
"y": 1080,
"id": "42025056566c8238",
"type": "function",
"name": "flow_set_disponible",
"func": "var disponible_var;\nflow.set(\"disponible_var\",msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 410,
"y": 1080,
"a6f9ad551e15cd75"
"id": "0e6dff5df00be7dc",
"type": "function",
"func": "var ciclo_term_var\nflow.set(\"ciclo_term_var\",msg.payload);\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 500,
"4c504cb7b08f0b93"
"id": "98a53bb80c42c943",
"type": "inject",
"name": "INSERT Into lavadoras_v0",
"props": [
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "INSERT INTO lavadoras_v0 ( Num_lavadora, tipo_ciclo, ciclo_personalizado, remojo, operador, num_ticket, hora_inicio, hora_fin, disponible) VALUES ( '1', tipo_ciclo, 'Enjuague', 'Sin Remojo', 'CCG', '74403', NOW(), '2025-06-15 18:44:13', 'Falso');",
"x": 150,
"y": 220,
"38b9dfb8b8e6c204"
"id": "c2cfdddbf204e5c9",
"type": "ui_spacer",
"name": "spacer",
"order": 1,
"width": 12,
"height": 1
"id": "3e10e97bf1ddab3a",
"type": "MySQLdatabase",
"host": "192.168.1.209",
"port": "3306",
"db": "hospitalv1",
"tz": "",
"charset": "UTF8"
"id": "ea5811b1fe9d49fa",
"type": "ui_group",
"name": "User Values",
"tab": "80597a7c0d642169",
"order": 1,
"disp": true,
"width": 12,
"collapse": false,
"className": ""
"id": "0f6966b00b831166",
"type": "s7 endpoint",
"transport": "iso-on-tcp",
"address": "192.168.1.2",
"port": "102",
"rack": "0",
"slot": "1",
"localtsaphi": "01",
"localtsaplo": "00",
"remotetsaphi": "01",
"remotetsaplo": "00",
"connmode": "rack-slot",
"adapter": "",
"busaddr": 2,
"cycletime": 1000,
"timeout": 2000,
"name": "Hospital1",
"vartable": [
"addr": "DB17,I0",
"name": "Num_Lavadora"
"addr": "DB17,X2.0",
"addr": "DB17,S4.15",
"addr": "DB17,S260.15",
"name": "Personalizado"
"addr": "DB17,S516.15",
"name": "Remojo"
"addr": "DB17,S772.15",
"name": "Usuario"
"addr": "DB17,DI1028",
"addr": "DB17,DTL1032",
"name": "Hora_inicio"
"addr": "DB17,DTL1044",
"name": "Hora_Fin"
"addr": "DB17,S1056.15",
"name": "Disonible"
"id": "80597a7c0d642169",
"type": "ui_tab",
"name": "DB",
"icon": "dashboard",
"order": 1,
"disabled": false,
"hidden": false
