Radio button set that sends message on actual radio button selection? The existing, official radio button example, creates a radio button list, but the selection is not communicated back to NR until the associated button is clicked. Is there a way to avoid creating or using the button? That a message is generated as the actual radio button is selected, or clicked? Can an defined script action function call node.send? That would be one way to do it, right?
<div >
<table>
<tr>
<td>
<md-button ng-click="send({payload:mirror})">
Select
</md-button>
</td>
<td>
<ul>
<li ng-repeat="mirror in msg.payload track by $index" style="list-style-type: none;">
<label>
<input type="radio" ng-model="$parent.mirror" value="{{mirror}}" name="data" />{{mirror}}
</label>
</li>
</ul>
</td>
</tr>
</table>
</div>
The above uses the button method to communicate the selected radio button, but I would like to remove the need for the button object. Tried the following, but I suspect I cut a corner and thus it is not working, don't seem to get a message back.
var theList = document.getElementById("List").getElementsByTagName('li');
for (var i=0; i < theList.length; i++) {
theList[i].addEventListener('click', Event, false);
function Event() {
node.send( { payload: this.innerHTML } );
</script>
<div >
<table>
<tr>
<td>
Select
</md-button>
</td>
<td>
<ul id="List">
<label>
</label>
</li>
</ul>
</td>
</tr>
</table>
</div>
