Thank you fixed I think.
[{"id":"1dc2aa68.579f46","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"67e2f110.35bbe","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"CSS only ","order":1,"width":0,"height":0,"format":"<style>\n    :root {\n      --dashboard-unit-width: 48px;\n      --dashboard-unit-height: 48px;\n      --remote-button-background: black;\n      --remote-button-foreground: #cccccc;\n    }\n    .nr-dashboard-template {\n        padding: 0px;\n    }\n   \n    .remote-button:not([disabled]):hover{\n         background-color: #232323 !important;\n    }\n\n    .remote-button.red:not([disabled]) {\n        background-color: #cc0000;\n        color: var(--remote-button-foreground);\n    }\n    .remote-button.green:not([disabled]) {\n        background-color: #00bb00;\n        color: var(--remote-button-foreground);\n    }\n    \n\n    /*   This is the normal button definition  */\n    .remote-button{\n        background-color: var(--remote-button-background) !important;\n        color: var(--remote-button-foreground);\n        height: var(--dashboard-unit-height);\n        width: 100%;\n        border-radius: 10px;\n        font-size:1.0em;\n        font-weight:normal;\n        margin: 0;\n        min-height: 36px;\n        min-width: unset;\n        line-height: unset;\n    }\n    /*  This is a sub-set which is invoked by */\n    /*  <md-button class=\"md-button remote-button bigger\"> */\n    /*  note the (space) \"bigger\" at the end.  */\n    .remote-button.bigger{\n        font-weight:bold;\n        font-size:1.5em;\n    }\n    /*  This is for buttons with a lot of text.  `font-size:0.7em` */\n    /*  makes the font 70% normal size  */\n    .remote-button.small{\n        font-size:0.7em;\n    }\n    /*  This is for buttons with just icons, to upsize the size */\n    /*  of the icon with the line: */\n    /*  <i class=\"fa fa-fw fa-plus remote-icon\"> in the other node  */\n    .remote-icon{\n        font-size:2.0em;\n    }\n    /*  This is the same as the other one, but it makes the icon smaller  */\n    .remote-iconS{\n        font-size:0.5em;\n    }\n    .remote-button.red{\n        background-color: #cc0000 !important;\n    }\n    .remote-button.green{\n        background-color: #00bb00 !important;\n    }\n    .remote-button.blue{\n        background-color: #0000dd !important;\n    }\n    .remote-button.red.disabled {\n        background-color: #440000 !important;\n        color: #666666 !important;\n    }\n    .remote-button.green.disabled {\n        background-color: #004400 !important;\n        color: #666666 !important;\n    }\n    .remote-button.blue.disabled {\n        background-color: #000066 !important;\n        color: #666666 !important;\n    }\n    .remote-button.disabled {\n        cursor: not-allowed;\n        pointer-events: none;\n        background-color: #222222;\n        color: #666666;\n    }\n\n    .remote-button.blinking {\n        animation: blink-animation 1s steps(5, start) infinite;\n        animation-timing-function: ease;\n        -webkit-animation: blink-animation 1s steps(5, start) infinite;\n    }\n    @keyframes blink-animation {\n        to { visibility: hidden; }\n    }\n    @-webkit-keyframes blink-animation {\n        to { visibility: hidden; }\n    }\n.remote-button.warning {\n  color: red;\n}\n\n.remote-button.animated .remote-button.warning {\n  -webkit-animation: pulse 1s infinite;\n  animation: pulse 1s infinite;\n}\n\n@-webkit-keyframes pulse {\n  0% {\n    opacity: 0.2\n  }\n\n  35% {\n    opacity: 1.0\n  }\n\n  100% {\n    opacity: 0.2\n  }\n}\n\n@keyframes pulse {\n  0% {\n    opacity: 0.2\n  }\n\n  35% {\n    opacity: 1.0\n  }\n\n  100% {\n    opacity: 0.2\n  }\n}\n\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","x":160,"y":40,"wires":[[]]},{"id":"c3cd9eec.3dd3","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"script for all buttons with class remote-button","order":25,"width":"1","height":"1","format":"<div>\n<!--diliberately emtpy - only need the script below -->\n</div>\n\n<script>\n\n(function($scope) {\n//debugger\n\n    //cause a small delay while things load \n    //ideally this would be an init event or on all parts of document loaded\n    //(may not be necessary!)\n    setTimeout(function() {\n        //debugger\n        $scope.init();\n    },100);\n    \n    var BUTTON_CLASS = \".remote-button\";\n\n    /** \n     * Initialise all buttons with class BUTTON_CLASS\n    */\n    $scope.init = function () {\n        //debugger\n        console.log(\"$scope.init called. Adding event handlers to all buttons with class '\" + BUTTON_CLASS + \"'.\");\n        var clickButtons = $(BUTTON_CLASS + \":not([data-buttontype='repeater'])\") \n        clickButtons.click(function(e){\n            //debugger\n            var btn = $(this)\n            var type = btn.data(\"buttontype\");//get the button type from attribute data-buttontype=\"xxxxx\"\n            var topic = btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n            var payload = btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\n            \n            if(type == \"toggle\"){\n                var newPayload = payload == 1 ? 0 : 1;\n                setButtonState(btn,newPayload)\n                $scope.send({\"topic\":topic,\"payload\":newPayload, \"event\": \"click\"})\n            } else {\n                $scope.send({\"topic\":topic,\"payload\":payload})\n            }\n        }); \n        \n\n        var repeatButtons = $(BUTTON_CLASS + \"[data-buttontype='repeater']\") \n        repeatButtons.on('mousedown touchstart',function(e) {\n            e.preventDefault();\n            e.stopPropagation();\n            console.log(e.type);//remove me after debugging\n            var btn = this;\n            var $btn = $(btn);\n            if(btn._intervalId) return; //already in operation\n            btn._topic = $btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n            btn._payload = $btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\n            btn._interval = $btn.data(\"interval\");//get the desired repeat duration\n            if(isNumeric(btn._interval) == false || btn._interval < 1) btn._interval = 300;//prevent zero & non numeric timeout value\n            var max = $btn.data(\"max\");//get the max repeat count\n            if(isNumeric(max) && max > 0) \n                btn._max = parseInt(max);\n            else\n                btn._max = undefined;\n            btn._count = 1;\n            $scope.send({\"topic\":btn._topic,\"payload\":btn.payload,\"event\":\"down\", \"count\": btn._count})\n            btn._lastevent = \"down\";\n            //remove any existing timer\n            if(btn._intervalId){\n                clearInterval(btn._intervalId);\n                btn._intervalId = null;\n            }\n            //start the timer if conditions are ok\n            if(!btn._max || (btn._max && btn._count < btn._max)){\n                btn._intervalId = setInterval(function() {\n                    if(btn._max && btn._count >= btn._max){\n                        clearInterval(btn._intervalId);\n                        btn._intervalId = null;\n                        return;\n                    }                    \n                    btn._count = btn._count + 1;\n                    $scope.send({\"topic\":btn._topic,\"payload\":btn.payload,\"event\":\"down\", \"count\": btn._count})\n                },btn._interval); \n            }\n        }).on('mouseup blur focusout mouseout touchend',function(e) {\n            e.preventDefault();\n            e.stopPropagation();\n            console.log(e.type);//remove me after debugging\n            var btn = this;\n            var $btn = $(btn);\n            \n            //next, if data-fireonup == true, then fire up event\n            var sendUpEvent = $btn.data(\"fireonup\") == true;\n            if(sendUpEvent && btn._lastevent === \"down\"){\n                btn._lastevent = \"up\"\n                $scope.send({\"topic\":btn._topic,\"payload\":btn._payload,\"event\":\"up\"})\n            }\n            \n            //finally, if the timer id is still valid, clear it (stop repeater)\n            if(btn._intervalId){\n                clearInterval(btn._intervalId);//stop timer\n                btn._intervalId = null;//clear timer id\n            }\n        });\n           \n    };\n    \n    //watch for node-red msgs\n    $scope.$watch('msg', function(msg) {\n        //debugger\n        if(!msg){ //if no msg \n            console.log(\"$scope.$watch('msg', ...) - msg is empty\");\n            return;\n        }\n        if(!msg.topic){ //if no topic set found\n            console.log(\"msg.topic is empty - cannot match this to any button\")\n            return; //stop processing!\n        }\n\n        var buttonSelector =  BUTTON_CLASS + \"[data-topic='\" + msg.topic + \"']\" \n        var $btn = $(buttonSelector);//get the button\n        \n        if(!$btn.length){ //if no button found\n            console.log(buttonSelector + \" not found - cannot set state\")\n            return; //stop processing!\n        }\n        \n        if($btn.length > 1){ //if MORE than one button found\n            console.log(buttonSelector + \" found more than 1 button - is this intended? Do you have the same data-topic set on multiple buttons?\")\n        }\n        \n        //see if this is a command - if so, process the command\n        if(typeof msg.payload === \"object\" && msg.payload.command){\n            processCommand($btn, msg.payload)\n            return;\n        }        \n        \n        if($btn.data(\"buttontype\") === \"toggle\"){\n            if(msg.payload == \"1\"){\n                setButtonState($btn, 1);\n            } else if(msg.payload == \"0\"){\n                setButtonState($btn, 0);\n            } else {\n               console.log(\"Invalid toggle value in msg.payload, cannot set \" + buttonSelector + \". Ensure msg.payload is either 0 or 1\") \n            }\n        }\n\n    }); \n    \n    /** \n    * helper function to set the correct icon & update the \"data-payload\" memory \n    */\n    function setButtonState($btn, state){\n        \n        $btn.data(\"payload\", state);//set data-payload to new state value (used as a memory)\n        \n        //determine the opposite state\n        var oppositeState;\n        if(state == \"1\" || state === 1){\n            state = 1; //normalise to a number\n            oppositeState = 0;\n        } else {\n            state = 0; //normalise to a number\n            oppositeState = 1;\n        }\n        \n        var $icon = $btn.find(\"i\"); //get the <i> element\n        if(!$icon.length){\n            $icon = $btn.find(\"span\"); //get the <span> element instead!\n        }\n        if(!$icon.length){\n            console.log(\"<i> or <span> not found inside button - cant toggle the icon!\")\n            return;//exit this function - nothing to toggle!\n        }\n        \n        //get the old icon and new icon names\n        var oldIcon = $btn.data(\"icon\" + oppositeState); //get icon1 or icon2 depending on oppositeState\n        var newIcon = $btn.data(\"icon\" + state); //get icon1 or icon2 depending on newPayload\n       \n        //if we have newIcon and an actual DOM element ($icon) - update it...\n        if(newIcon && $icon.length){\n            if(newIcon.includes(\"fa-\")){ \n                $icon.removeClass(oldIcon).addClass(newIcon);  // fontawesome\n            } else { \n                $icon.text(newIcon); // MDI\n            }\n        }\n    }\n        \n    function processCommand($btn, payload){\n        //first check payload is correct format...\n        if(!payload || !payload.command || !payload.value){\n            console.log(\"Cannot process command. Expected a payload object with .command and .value. \")\n        }\n        var cmd = payload.command.trim();\n        switch(cmd){\n            case \"addClass\":\n                $btn.addClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n                break;\n            case \"toggleClass\":\n                $btn.toggleClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n                break;\n            case \"removeClass\":\n                $btn.removeClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n                break;\n            default:\n                console.log(\"command '\" + payload.command + \"' is not supported\")\n        }\n    }        \n        \n    /** \n    * helper function to determine a value is REALLY a number \n    */\n    function isNumeric(n){\n        if(n === \"\") return false;\n        if(n === true || n === false) return false;\n        return !isNaN(parseFloat(n)) && isFinite(n);\n    }\n   \n\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":230,"y":400,"wires":[["8fc2df4d.a1bd3"]]},{"id":"8fc2df4d.a1bd3","type":"debug","z":"1dc2aa68.579f46","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":450,"y":400,"wires":[]},{"id":"f9050d6a.1bd0c","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"lock","order":23,"width":"1","height":"1","format":"<div>\n   <md-button class=\"md-button remote-button bigger\" \n              data-payload=\"0\" \n              data-buttontype=\"toggle\"\n              data-topic=\"lock\"\n              data-icon0=\"fa-unlock\"\n              data-icon1=\"fa-lock\"\n              aria-label=\"lock\"\n              >\n      <span class=\"fa fa-unlock\" aria-hidden=\"true\"> </span>\n   </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":230,"y":360,"wires":[[]]},{"id":"f8c597b1.8d5b88","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass blinking, on lock","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"lock","payload":"{\"command\":\"toggleClass\",\"value\":\"blinking\"}","payloadType":"json","x":160,"y":640,"wires":[["c3cd9eec.3dd3"]]},{"id":"49f3f717.1f2d38","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass red, on lock","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"lock","payload":"{\"command\":\"toggleClass\",\"value\":\"red\"}","payloadType":"json","x":140,"y":680,"wires":[["c3cd9eec.3dd3"]]},{"id":"149b90bd.321fbf","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass disabled, on lock","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"lock","payload":"{\"command\":\"toggleClass\",\"value\":\"disabled\"}","payloadType":"json","x":160,"y":720,"wires":[["c3cd9eec.3dd3"]]},{"id":"dd392375.944b4","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"1","order":2,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"1\"\n    data-payload=\"1\">1\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":80,"wires":[[]]},{"id":"708944c1.3a82dc","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass blinking, on 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"1","payload":"{\"command\":\"toggleClass\",\"value\":\"blinking\"}","payloadType":"json","x":150,"y":460,"wires":[["c3cd9eec.3dd3"]]},{"id":"779c226a.f6180c","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass red, on 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"1","payload":"{\"command\":\"toggleClass\",\"value\":\"red\"}","payloadType":"json","x":140,"y":560,"wires":[["c3cd9eec.3dd3"]]},{"id":"c328f7d2.a1e6a8","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass disabled, on 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"1","payload":"{\"command\":\"toggleClass\",\"value\":\"disabled\"}","payloadType":"json","x":150,"y":600,"wires":[["c3cd9eec.3dd3"]]},{"id":"12615388.2078ac","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"2","order":3,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"2\"\n    data-payload=\"2\">2\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":230,"y":80,"wires":[[]]},{"id":"a144043c.5c5208","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"3","order":4,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"3\"\n    data-payload=\"3\">3\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":350,"y":80,"wires":[[]]},{"id":"37182909.4335e6","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"4","order":5,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"4\"\n    data-payload=\"4\">4\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":110,"y":120,"wires":[[]]},{"id":"7c0b2d.405e64d4","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"5","order":6,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"5\"\n    data-payload=\"5\">5\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":230,"y":120,"wires":[[]]},{"id":"90bf9750.269e18","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"6","order":7,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"6\"\n    data-payload=\"6\">6\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":350,"y":120,"wires":[[]]},{"id":"c3b1aca7.213f5","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"7","order":8,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"7\"\n    data-payload=\"7\">7\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":110,"y":160,"wires":[[]]},{"id":"4c4a663f.3c9e58","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"8","order":9,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"8\"\n    data-payload=\"8\">8\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":230,"y":160,"wires":[[]]},{"id":"f03c10ff.9eff","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"9","order":10,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"9\"\n    data-payload=\"9\">9\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":350,"y":160,"wires":[[]]},{"id":"e792b2b7.e1a23","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"info","order":11,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button\"\n    data-topic=\"info\"\n    data-payload=\"info\"\n    aria-label=\"info\"\n   >\n      <i class=\"fa fa-info-circle remote-icon\"></i>\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":110,"y":200,"wires":[[]]},{"id":"cd1651b5.a4d9d","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"0","order":12,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button bigger\"\n    data-topic=\"0\"\n    data-payload=\"0\">0\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":230,"y":200,"wires":[[]]},{"id":"49f4c2c7.96749c","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"prev","order":13,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button\"\n    data-topic=\"prev\"\n    data-payload=\"prev\"\n    aria-label=\"previous\"\n   >\n      <i class=\"fa fa-rotate-left remote-icon\"></i>\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":350,"y":200,"wires":[[]]},{"id":"633a01d0.4e67b","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"vol +  *","order":14,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button\" \n        data-buttontype=\"repeater\"\n        data-interval=\"200\"\n        data-topic=\"volume/plus\"\n        data-payload=\"volume/plus\"\n        aria-label=\"volume plus\"\n    >\n    <span class=\"fa fa-plus remote-icon\"> </span>\n   </md-button>\n</div>\n\n\n","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":110,"y":240,"wires":[[]],"info":"<div id=\"regular_plus\">\n   <md-button class=\"md-button remote-button\">\n      <i class=\"fa fa-plus remote-icon\"></i>\n   </md-button>\n</div>"},{"id":"e6e86f98.668b6","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"mute","order":15,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button\" \n              data-payload=\"1\" \n              data-buttontype=\"toggle\"\n              data-topic=\"mute\"\n              data-icon0=\"volume_off\"\n              data-icon1=\"volume_mute\"\n              aria-label=\"volume mute\"\n              >\n      <i class=\"material-icons md-48\">volume_mute</i>\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":230,"y":240,"wires":[[]],"info":"  class=\"material-icons\"> volume_off"},{"id":"4d29a992.a9e078","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"Ch +","order":16,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button\" \n        data-topic=\"channel/up\"\n        data-payload=\"up\" \n        aria-label=\"channel up\"\n    >\n    <i class=\"fa fa-chevron-up remote-icon\"></i>\n   </md-button>\n</div>\n\n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":350,"y":240,"wires":[[]]},{"id":"f4f0a4be.6d7dd8","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"vol -  *","order":17,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button\"\n        data-buttontype=\"repeater\"\n        data-interval=\"200\"\n        data-topic=\"volume/minus\"\n        data-payload=\"volume/minus\"\n        aria-label=\"volume minus\"\n    >\n    <span style=\"color:{{msg.colour}}\" class=\"fa fa-minus remote-icon\"> </span>\n   </md-button>\n</div>\n\n","storeOutMessages":true,"fwdInMessages":false,"templateScope":"local","x":110,"y":280,"wires":[[]],"info":"<div id=\"regular_plus\">\n   <md-button class=\"md-button remote-button\">\n      <i class=\"fa fa-minus remote-icon\"></i>\n   </md-button>\n</div>\n"},{"id":"e477c8bb.78bab8","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"ch list","order":18,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button\"\n    data-topic=\"channel/list\"\n    data-payload=\"list\"\n    aria-label=\"channel list\"\n   >\n      <i class=\"fa fa-list-alt remote-icon\"></i>\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":230,"y":280,"wires":[[]]},{"id":"566b6c8e.81a674","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"Ch -","order":19,"width":1,"height":1,"format":"<div>\n   <md-button class=\"md-button remote-button\" \n        data-topic=\"channel/down\"\n        data-payload=\"down\" \n        aria-label=\"channel down\"\n    >\n    <i class=\"fa fa-chevron-down remote-icon\"></i>\n   </md-button>\n</div>\n\n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":350,"y":280,"wires":[[]]},{"id":"9bd60a53.fa18e8","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"NetFlix","order":20,"width":"1","height":"1","format":"<div>\n    <md-button \n        class=\"md-button remote-button\"\n        data-topic=\"netflix\"\n        data-payload=\"netflix\"\n        aria-label=\"Netflix\"\n    >\n        <img\n            class=\"remote-icon\"\n            style=\"width: 36px; padding-top: 2px\"\n            src=\"data:image/png;base64,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\">\n        />\n    </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":110,"y":320,"wires":[[]]},{"id":"7acbb76f.72a2d8","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"Home","order":21,"width":"1","height":"1","format":"<div>\n   <md-button class=\"md-button remote-button\" \n        data-topic=\"home\"\n        data-payload=\"home\" \n        aria-label=\"home\"\n    >\n    <i class=\"fa fa-home remote-icon\"> </i>\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":230,"y":320,"wires":[[]]},{"id":"ffe2d03d.fe585","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"Vid","order":22,"width":"1","height":"1","format":"<div>\n   <md-button class=\"md-button remote-button small\" \n        data-topic=\"video\"\n        data-payload=\"video\" \n    >Video\n   </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":350,"y":320,"wires":[[]]},{"id":"19ea2b3a.6c3355","type":"ui_template","z":"1dc2aa68.579f46","group":"1df0f0ce.3ed5cf","name":"lock2 (red)","order":24,"width":"1","height":"1","format":"<div>\n   <md-button class=\"md-button remote-button bigger red\" \n              data-payload=\"0\" \n              data-buttontype=\"toggle\"\n              data-topic=\"lock2\"\n              data-icon0=\"fa-unlock\"\n              data-icon1=\"fa-lock\"\n              aria-label=\"lock\"\n              >\n      <span class=\"fa fa-unlock\" aria-hidden=\"true\"> </span>\n   </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":370,"y":360,"wires":[[]]},{"id":"957b76f5.c32d58","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass blinking, on volume/plus","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"volume/plus","payload":"{\"command\":\"toggleClass\",\"value\":\"blinking\"}","payloadType":"json","x":460,"y":460,"wires":[["c3cd9eec.3dd3"]]},{"id":"6ef314bc.d81e1c","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass red, on volume/plus","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"volume/plus","payload":"{\"command\":\"toggleClass\",\"value\":\"red\"}","payloadType":"json","x":450,"y":600,"wires":[["c3cd9eec.3dd3"]]},{"id":"caf4da77.ef4268","type":"inject","z":"1dc2aa68.579f46","name":"addClass animated, on volume/plus","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"volume/plus","payload":"{\"command\":\"addClass\",\"value\":\"animated\"}","payloadType":"json","x":500,"y":720,"wires":[["c3cd9eec.3dd3"]]},{"id":"d08bcb74.2dc7b8","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass green, on volume/plus","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"volume/plus","payload":"{\"command\":\"toggleClass\",\"value\":\"green\"}","payloadType":"json","x":480,"y":640,"wires":[["c3cd9eec.3dd3"]]},{"id":"6cad115.0b982f","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass blue, on volume/plus","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"volume/plus","payload":"{\"command\":\"toggleClass\",\"value\":\"blue\"}","payloadType":"json","x":490,"y":680,"wires":[["c3cd9eec.3dd3"]]},{"id":"9ca57523.191eb8","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass blinking, on volume/plus","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"volume/plus","payload":"{\"command\":\"toggleClass\",\"value\":\"blinking\"}","payloadType":"json","x":480,"y":500,"wires":[["c3cd9eec.3dd3"]]},{"id":"73e56d61.edc2d4","type":"inject","z":"1dc2aa68.579f46","name":"toggleClass warning, on volume/plus","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"volume/plus","payload":"{\"command\":\"toggleClass\",\"value\":\"warning\"}","payloadType":"json","x":500,"y":540,"wires":[["c3cd9eec.3dd3"]]},{"id":"71b4ada0.246c04","type":"inject","z":"1dc2aa68.579f46","name":"addClass animated, on 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"1","payload":"{\"command\":\"addClass\",\"value\":\"animated\"}","payloadType":"json","x":150,"y":500,"wires":[["c3cd9eec.3dd3"]]},{"id":"1df0f0ce.3ed5cf","type":"ui_group","z":"","name":"Full_Remote2","tab":"d8c345fb.e094c8","order":3,"disp":false,"width":"3","collapse":false},{"id":"d8c345fb.e094c8","type":"ui_tab","z":"","name":"HDMI_TV_control","icon":"dashboard","order":7,"disabled":false,"hidden":false}]
