Random node ids in subflows
Hi guys,
The context: we're using Node-RED to interact with a conversational API, this means that at some point a custom node calls an endpoint and, when the conversation continues, the API triggers a particular event, at this point the flow should resume from the point it stopped.
The problem is with the code below
 function createNodeInSubflow(subflowInstanceId, def) {
   let node = clone(def);
   let nid = redUtil.generateId();
the id of a node inside a subflow is random, it changes at every restart, which makes impossible to use it as a reference for resuming the flow in the same point it was interrupted calling the API (in case Node-red restarts the original id is lost).
Is there a solution for this problem (having a deterministic reference of what node it's execute in the flow) which doesn't include
  • patching the core of Node-RED
  • keeping the "status" of the execution inside Node-RED (not a viable solution for us)
Thanks and sorry if this post is a little bit vague
Guido
You can use the _path property of the node. That is entirely deterministic between restarts.
Thanks, this is really helpful, one last question: is there an helper method to get the node instance given the path (or a way to send a msg to a node knowing the path).
Thanks again
Guido
There is not a helper function for that as it is not something regular nodes have any need to do.
