Hi there,
we have a problem, the Raspberry Pi is not able to boot the NodeRed anymore after setting the time intervall of the injection node to short.
The injection node was used, to smaple data with the I2C node. It was working with a sample rate of 100 ms, but after setting the sample time to 10 ms, the performance of Raspberry Pi seems to be not enough to open Node Red again. (Only half page is loading in the browser).
Is there any possibility to use the files in the NodeRed folder to open the flow on another machine, without exporting?! Or is it possible to change the injection sample rate, within a file, so that we wouldn't need to open the NodeRed flow?!
Other than that, would there be any other possibility to solve this problem?
Thanks in advance.
p.s. Unfortunatly we can't provide any data, pictures or code, because we are not able to open Node Red in the browser.
