Unfortunately it fails at 'installing node.js'. I believe it is because the script is assuming an ARM processor. I have been able to install node.js and node red manually - but it doesn't come with some of the nice features, like being able to use the systemd script for running as a service.
Is there perhaps someone who knows how to modify the RPi install script to suit a i686 processor ?
Hi, im trying the same thing but i cant install node8 manually couse its no longer supported. I tried install node10 and then run the script but Im still stuck on "update Node.js LTS" x Failed to install Node.js - Exit
You would be better off just installing one of the Ubuntu desktop variants I prefer Ubuntu mate but up to you. That will get you 64 bit and the script will work.
