Raspberry sense hat problem
Trying to get my sense hat working after a crash of my pi.
created a new image ( basic ) and installed node red.
using nr version 2.2.0
every time i get the message [node-red-node-pi-sense-hat/sensehat] Error: Can't find Sense HAT python libraries. Run sudo apt-get install sense-hat
on install of sudo pip-3.2 install pillow i get sudo: pip-3.2: command not found
maybe this is the problem?
i cannot find in google how to solve that
thanks!
See if the hack here helps
Thanks!
So change python3 to python2?
nope that is not working, found that solution before.
The issue is that the node calls a python program that was written using things that are not compatible with python3. I took a look awhile ago and did some work, but dropped it because of other claims on my time.
Recently I’ve been doing a little python coding for a project I’m developing and it may shine some light on what needs to be changed in the node’s python program. I’ll see if I can scrounge some time (in between watching grandkids shoveling snow, doing taxes etc) to take a look this week. No promises though.
:pray: :pray: :pray:
Thanks!
