I finally added the latest touch to my PiCam setup... keyboard control. Specifically the arrow keys on the keyboard (thanks to some posted code from @Steve-Mcl ) that I was able to add to the adjustment of both pan and tilt.
It is a bit of a spiderweb but it works.
The camera can be adjusted via the sliders, the buttons or the arrow keys on the keyboard (of the PC running the dashboard)
The trigger buttons disable after initial press of CLICK ME until camera has had time to snap the shot, then emailing is an option.
And additional white or IR lighting can be used as needed.
The hardware:
- RPi 3B
- Raspberry Pi Camera NoIR (AKA IR filter removed)
- Standard servos and P&T framework
- PCA9685 i2c board for the servo control
- BrightPi LED light to supply the white or IR lighting
The flow:
"id": "426d244e6a840d51",
"type": "inject",
"z": "ce319a63567d1926",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "",
"topic": "",
"payload": "true",
"payloadType": "bool",
"x": 110,
"y": 120,
"3eeee6993133b587"
"id": "d7ea50835c54aece",
"type": "exec",
"command": "raspistill -w 300 -h 195 -n -o",
"addpay": "payload",
"append": "",
"useSpawn": "false",
"timer": "",
"winHide": false,
"oldrc": false,
"x": 360,
"y": 160,
"7e1ed92f26b34a3c"
"id": "c6261caebc9cf9b2",
"type": "base64",
"action": "str",
"property": "payload",
"x": 340,
"y": 100,
"f0724a7e706aa3d9",
"d18cf09a30d0de76"
"id": "f0724a7e706aa3d9",
"type": "template",
"d": true,
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "<img width=\"300px\" height=\"195px\" src=\"data:image/jpg;base64,{{{payload}}}\">",
"output": "str",
"x": 580,
"y": 60,
"9460a8944929a327"
"id": "9460a8944929a327",
"type": "ui_template",
"d": true,
"group": "eb23a053.4aa63",
"name": "Snapshot Template",
"order": 1,
"width": 6,
"height": 4,
"format": "<div ng-bind-html=\"msg.payload\">\ndocument.\"msg.payload\".style.backgroundImage='none';\n</div>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": true,
"templateScope": "local",
"x": 750,
"y": 60,
"id": "a596243270bc62dc",
"type": "PCA9685 out",
"name": "PWM Output 0 (Pan Servo)",
"pca9685": "6ce45bce.cdff94",
"channel": "15",
"payload": "",
"unit": "microseconds",
"onStep": "0",
"x": 1020,
"y": 540,
"id": "d041f2c5c1af0f2e",
"name": "PWM Output 1 (Tilt Servo)",
"channel": "14",
"payload": "",
"onStep": "0",
"x": 1020,
"y": 620,
"id": "f5285e2fcaf21a50",
"type": "ui_button",
"group": "d3d5aef6.5754d",
"order": 1,
"width": 0,
"height": 0,
"passthru": false,
"label": "CLICK ME",
"tooltip": "",
"color": "White",
"bgcolor": "Blue",
"icon": "",
"payload": "1",
"payloadType": "num",
"topic": "topic",
"topicType": "msg",
"x": 130,
"y": 200,
"71c04ceed3a62738",
"3eeee6993133b587"
"id": "71c04ceed3a62738",
"type": "trigger",
"name": "Trigger delay",
"op1": "",
"op2": "",
"op1type": "pay",
"op2type": "str",
"duration": "8",
"extend": false,
"overrideDelay": false,
"units": "s",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 2,
"x": 150,
"y": 360,
"931bb7d59c550881"
"c6bc35aa878d479f"
"id": "931bb7d59c550881",
"type": "change",
"name": "msg.enabled FALSE",
"rules": [
"t": "set",
"p": "enabled",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 160,
"y": 260,
"f5285e2fcaf21a50",
"bf2ab825c966b516"
"id": "c6bc35aa878d479f",
"type": "change",
"name": "msg.enabled TRUE",
"rules": [
"t": "set",
"p": "enabled",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 150,
"y": 300,
"f5285e2fcaf21a50",
"bf2ab825c966b516"
"id": "3dfd73321652f851",
"type": "comment",
"name": "Snap a RPiCam picture for display- with P&T",
"info": "",
"x": 210,
"y": 20,
"id": "3452efe35ccfe90b",
"type": "exec",
"command": "i2cset -y 1 0x70 0x00 0x5a && i2cset -y 1 0x70 0x09 0x0f && i2cset -y 1 0x70 0x02 0x32 && i2cset -y 1 0x70 0x04 0x32 && i2cset -y 1 0x70 0x05 0x32 && i2cset -y 1 0x70 0x07 0x32",
"addpay": "",
"append": "",
"timer": "",
"oldrc": false,
"name": "All White Full Bright",
"x": 950,
"y": 840,
"id": "da8d841a11491b1f",
"type": "exec",
"command": "i2cset -y 1 0x70 0x00 0x00",
"addpay": "",
"append": "",
"timer": "",
"winHide": false,
"oldrc": false,
"name": "All OFF",
"x": 920,
"y": 780,
"id": "1be9734b3e515b18",
"type": "exec",
"command": "i2cset -y 1 0x70 0x00 0xa5 && i2cset -y 1 0x70 0x09 0x0f && i2cset -y 1 0x70 0x01 0x32 && i2cset -y 1 0x70 0x03 0x32 && i2cset -y 1 0x70 0x06 0x32 && i2cset -y 1 0x70 0x08 0x32",
"addpay": "",
"append": "",
"timer": "",
"oldrc": false,
"name": "All IR Full Bright",
"x": 940,
"y": 900,
"id": "90d1c8286d071012",
"type": "ui_multistate_switch",
"name": "BrightPi Light",
"order": 3,
"width": 0,
"height": 0,
"label": "BrightPi Light",
"stateField": "payload",
"enableField": "enable",
"rounded": true,
"useThemeColors": true,
"hideSelectedLabel": false,
"options": [
"label": "OFF",
"value": "0",
"valueType": "num",
"color": "#009933"
"label": "White",
"value": "1",
"valueType": "num",
"color": "#999999"
"label": "IR",
"value": "2",
"valueType": "num",
"color": "#ff6666"
"x": 650,
"y": 820,
"b27c4e32e1a11ec4"
"id": "b27c4e32e1a11ec4",
"type": "switch",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "eq",
"v": "1",
"vt": "num"
"t": "eq",
"v": "2",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 3,
"x": 630,
"y": 880,
"da8d841a11491b1f",
"d041f2c5c1af0f2e",
"a596243270bc62dc"
"3452efe35ccfe90b"
"1be9734b3e515b18"
"id": "db673212cc5f686a",
"type": "link out",
"name": "Tenserflow",
"links": [
"e9406dea66813d37"
"x": 775,
"y": 140,
"id": "ad2362e5d8c2f39d",
"type": "comment",
"name": "Send 0 to P&T to reset it for use after BrightPi",
"info": "",
"x": 930,
"y": 720,
"id": "9adcfd1d82a78e24",
"type": "comment",
"name": "BrightPi i2cset control",
"info": "",
"x": 680,
"y": 780,
"id": "115a7bc7335fea13",
"type": "inject",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "0",
"x": 630,
"y": 720,
"a596243270bc62dc",
"d041f2c5c1af0f2e",
"da8d841a11491b1f"
"id": "510a5ff0fe205358",
"type": "comment",
"name": "Pan & Tilt Servos",
"info": "",
"x": 120,
"y": 460,
"id": "bf2ab825c966b516",
"order": 2,
"width": 0,
"height": 0,
"passthru": false,
"label": "EMAIL",
"tooltip": "",
"color": "White",
"bgcolor": "Blue",
"icon": "",
"payload": "Raspi Camera Image",
"payloadType": "str",
"topic": "payload",
"topicType": "msg",
"x": 430,
"y": 280,
"92c3e64eb05e8cf4"
"id": "8be9af3b0ec0440c",
"type": "e-mail",
"z": "<PASS/KEY>",
"server": "<SMTP>",
"port": "<PORT>",
"secure": true,
"tls": true,
"name": "<EMAIL>",
"dname": "",
"credentials": {},
"x": 500,
"y": 360,
"id": "3eeee6993133b587",
"type": "change",
"name": "Set filename",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "/home/pi/node-red-static/picam.jpg",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 130,
"y": 160,
"d7ea50835c54aece"
"id": "92c3e64eb05e8cf4",
"type": "file in",
"name": "Grab image",
"filename": "/home/pi/node-red-static/picam.jpg",
"format": "",
"chunk": false,
"sendError": false,
"encoding": "none",
"allProps": false,
"x": 450,
"y": 320,
"8be9af3b0ec0440c"
"id": "e538f5fd3a7815ff",
"type": "inject",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "true",
"x": 430,
"y": 240,
"bf2ab825c966b516"
"id": "d632114fcddab87b",
"type": "image",
"width": "400",
"data": "payload",
"dataType": "msg",
"thumbnail": false,
"active": true,
"pass": false,
"outputs": 0,
"x": 800,
"y": 180,
"id": "41ee22d90ad16a8a",
"type": "file in",
"format": "",
"chunk": false,
"sendError": false,
"encoding": "none",
"allProps": false,
"x": 610,
"y": 140,
"d632114fcddab87b",
"c6261caebc9cf9b2",
"db673212cc5f686a"
"id": "7e1ed92f26b34a3c",
"type": "delay",
"pauseType": "delay",
"timeout": ".5",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"x": 600,
"y": 180,
"41ee22d90ad16a8a"
"id": "d18cf09a30d0de76",
"name": "Display image",
"order": 2,
"width": 6,
"height": 4,
"format": "<!DOCTYPE html>\n<html>\n<style>\n .img {\n border: 8px solid #000;\n border-radius: 8px;\n padding: 2px;\n width: 260px;\n }\n</style>\n\n<center>\n <table>\n <tr>\n <!-- Row 1 -->\n <td style=\"text-align: center\"><img src=\"data:image/jpg;base64,{{msg.payload}}\" class=img /></td>\n </tr>\n </table>\n</center>\n</html>",
"resendOnRefresh": false,
"x": 740,
"y": 100,
"id": "ac7c952dfd2bdf87",
"group": "2b5eec28.269ea4",
"name": "Keyboard",
"order": 1,
"width": 0,
"height": 0,
"format": "<div id=\"key_press\">waiting key</div>\n<script type=\"text/javascript\">\n(function(scope) {\n const _scope = scope;\n $('body').on(\"keyup\", function(e) { \n var keyCode = (e || event || {}).keyCode;\n if(keyCode >= 37 && keyCode <= 40) {\n $(\"#key_press\").text(\"Detected Key: \" + keyCode);\n _scope.send({payload: keyCode});\n } \n });\n})(scope);\n</script>",
"x": 160,
"y": 520,
"53d0c5ae1ffe495a"
"id": "b4a8db6e9e842570",
"type": "ui_slider",
"label": "Pan",
"tooltip": "",
"order": 2,
"width": 5,
"height": 1,
"passthru": false,
"outs": "end",
"topic": "topic",
"topicType": "msg",
"min": "500",
"max": "2200",
"step": "10",
"x": 590,
"y": 520,
"6a1aaa2a24c08602"
"id": "6a1aaa2a24c08602",
"type": "change",
"rules": [
"t": "set",
"p": "Pan",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 750,
"y": 520,
"a596243270bc62dc"
"id": "53d0c5ae1ffe495a",
"type": "change",
"name": "get slider values",
"rules": [
"t": "set",
"p": "Pan",
"pt": "msg",
"to": "Pan",
"tot": "flow"
"t": "set",
"p": "Tilt",
"pt": "msg",
"to": "Tilt",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 460,
"y": 580,
"7cfb3d35bac01fd0"
"id": "7cfb3d35bac01fd0",
"type": "function",
"name": "inc/dec/dheck",
"func": "const PanMIN = 500;\nconst PanMAX = 2200;\nconst TiltMIN = 2200;\nconst TiltMAX = 1300;\nconst INC = 100;\n\nlet Pan = msg.Pan || PanMIN;\nlet Tilt = msg.Tilt || PanMIN;\n\nswitch(msg.payload) {\n case 37:\n //left arrow\n Pan -= INC;\n break;\n \n case 38:\n //up arrow\n Tilt -= INC;\n break;\n \n case 39:\n //right arrow\n Pan += INC;\n break;\n\n case 40:\n //down arrow\n Tilt += INC;\n break;\n}\n\nif (Pan < PanMIN) {\n Pan = PanMIN;\n} else if (Pan > PanMAX) {\n Pan = PanMAX;\n}\n\nif (Tilt > TiltMIN) {\n Tilt = TiltMIN;\n} else if (Tilt < TiltMAX) {\n Tilt = TiltMAX;\n}\n\nlet msg1 = {payload: Pan};\nlet msg2 = {payload: Tilt};\n\nreturn [msg1,msg2];",
"outputs": 2,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 640,
"y": 580,
"73015db0703cd6ad",
"a596243270bc62dc"
"ac0ced8f6b3cac48",
"d041f2c5c1af0f2e"
"id": "73015db0703cd6ad",
"type": "change",
"rules": [
"t": "set",
"p": "Pan",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 410,
"y": 520,
"b4a8db6e9e842570"
"id": "5b2131a9de812e21",
"label": "Tilt",
"tooltip": "",
"order": 5,
"width": 1,
"height": 5,
"passthru": false,
"outs": "end",
"topic": "topic",
"topicType": "msg",
"min": "2200",
"max": "1300",
"step": "10",
"x": 590,
"y": 640,
"729e7730024f693b"
"id": "729e7730024f693b",
"type": "change",
"rules": [
"t": "set",
"p": "Tilt",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 750,
"y": 640,
"d041f2c5c1af0f2e"
"id": "ac0ced8f6b3cac48",
"type": "change",
"rules": [
"t": "set",
"p": "Tilt",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 410,
"y": 640,
"5b2131a9de812e21"
"id": "b783aebc9fe9895f",
"order": 9,
"width": 2,
"height": 1,
"passthru": false,
"label": "LT",
"tooltip": "",
"color": "",
"bgcolor": "",
"icon": "",
"payload": "37",
"topic": "topic",
"topicType": "msg",
"x": 90,
"y": 620,
"53d0c5ae1ffe495a"
"id": "2a68ff2c48c463b0",
"order": 7,
"width": 2,
"height": 1,
"passthru": false,
"label": "UP",
"tooltip": "",
"color": "",
"bgcolor": "",
"icon": "",
"payload": "38",
"topic": "topic",
"topicType": "msg",
"x": 150,
"y": 580,
"53d0c5ae1ffe495a"
"id": "f792211e7c2a8fe1",
"order": 10,
"width": 2,
"height": 1,
"passthru": false,
"label": "RT",
"tooltip": "",
"color": "",
"bgcolor": "",
"icon": "",
"payload": "39",
"topic": "topic",
"topicType": "msg",
"x": 210,
"y": 620,
"53d0c5ae1ffe495a"
"id": "0275633bef01376a",
"order": 13,
"width": 2,
"height": 1,
"passthru": false,
"label": "DN",
"tooltip": "",
"color": "",
"bgcolor": "",
"icon": "",
"payload": "40",
"topic": "topic",
"topicType": "msg",
"x": 150,
"y": 660,
"53d0c5ae1ffe495a"
"id": "eb23a053.4aa63",
"type": "ui_group",
"name": "Snapshot",
"tab": "75252f1b.e6fdd",
"order": 2,
"disp": true,
"width": "6",
"collapse": false
"id": "6ce45bce.cdff94",
"type": "PCA9685",
"deviceNumber": "1",
"address": "64",
"frequency": "50"
"id": "d3d5aef6.5754d",
"type": "ui_group",
"name": "Trigger",
"order": 3,
"disp": true,
"width": "6",
"collapse": false
"id": "2b5eec28.269ea4",
"type": "ui_group",
"name": "P&T",
"order": 1,
"disp": true,
"width": "6",
"collapse": false
"id": "75252f1b.e6fdd",
"type": "ui_tab",
"name": "Raspi Cam",
"icon": "camera",
"order": 2,
"disabled": false,
"hidden": false
