Raspivid and Node Red
I'm trying to work with raspistill and raspivid and am getting an odd error I can seem to work around.
raspistill is working but taspivid gets an error on file not found.
I even wrapped it all in a shell script and it works when I call it from the shell as root or pi.
#!/bin/bash
/usr/bin/raspivid -t 30000 -w 570 -h 570 -fps 25 -b 1200000 -p 0,0,570,570 -o /tmp/video.h264
/usr/bin/MP4Box -add /tmp/video.h264 /home/pi/Desktop/video.mp4
rm /tmp/video.h264
What would be great is if we could pull the cmd string into the ui_media
flows.json (3.6 KB)
Forgot how to get the flow to display correctly, so I uploaded it.
Go to a new line, click the </> button and paste it where indicated. Please do that with for us so we don't have to download the file, which is a pain. Thanks.
Also please show us the full error message.
Here is the error.
6/19/2020, 8:10:04 AM757eea11.09ccc4
Camera_Click : msg : Object
object
topic: "Camera_Click"
socketid: "RqjHg_zPbPmjmY-nAAAB"
_msgid: "f82efc8f.15138"
payload: string
/bin/sh: 1: Video: not found
rc: object
code: 127
message: "Command failed: Video Capture /usr/bin/raspivid -t 30000 -w 570 -h 570 -fps 25 -b 1200000 -p 0,0,570,570 -o /tmp/video.h264↵/bin/sh: 1: Video: not found↵"
[{"id":"1591fded.581fe2","type":"tab","label":"Video Capture","disabled":false,"info":""},{"id":"6e5e2f42.183ba8","type":"exec","z":"1591fded.581fe2","command":"raspistill","addpay":false,"append":"-vs -ex night -w 570 -h 570 -o -","useSpawn":"false","timer":"","oldrc":false,"name":"","x":660,"y":120,"wires":[["4f40679e.837c9"],[],[]]},{"id":"4f40679e.837c9","type":"base64","z":"1591fded.581fe2","name":"","action":"str","property":"payload","x":900,"y":240,"wires":[["c1afb31b.7911"]]},{"id":"c1afb31b.7911","type":"template","z":"1591fded.581fe2","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<img width=\"570px\" height=\"570px\" src=\"data:image/jpg;base64,{{{payload}}}\">","output":"str","x":1040,"y":240,"wires":[["a49e548c.732ac"]]},{"id":"a49e548c.732ac","type":"ui_template","z":"1591fded.581fe2","group":"6080d6c0.890608","name":"","order":4,"width":"17","height":"25","format":"<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1180,"y":240,"wires":[[]]},{"id":"ecb7836.0f9c7","type":"ui_switch","z":"1591fded.581fe2","name":"Camera_Click","label":"","tooltip":"","group":"6080d6c0.890608","order":2,"width":3,"height":"3","passthru":true,"decouple":"false","topic":"Camera_Click","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-pulse fa-3x fa-camera","oncolor":"green","offvalue":"false","offvalueType":"bool","officon":"fa-photo fa-3x","offcolor":"blue","x":135,"y":240,"wires":[["d21306bb.9751c"]],"l":false},{"id":"40adfa7.cfc1f84","type":"trigger","z":"1591fded.581fe2","op1":"","op2":"false","op1type":"pay","op2type":"bool","duration":"8","extend":false,"units":"s","reset":"","bytopic":"all","name":"igniter","x":390,"y":240,"wires":[["ecb7836.0f9c7","994ab145.0b08d"]]},{"id":"d21306bb.9751c","type":"switch","z":"1591fded.581fe2","name":"Camera","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":240,"y":240,"wires":[["40adfa7.cfc1f84"],[]]},{"id":"994ab145.0b08d","type":"switch","z":"1591fded.581fe2","name":"Click","property":"payload","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":530,"y":240,"wires":[["6e5e2f42.183ba8","ac7596c1.99aee"]]},{"id":"a7a4a4ec.caa168","type":"ui_media","z":"1591fded.581fe2","group":"2db625cf.759fb2","name":"","width":0,"height":0,"order":2,"category":"Desktop","file":"video.mp4","layout":"center","showcontrols":true,"loop":false,"onstart":false,"scope":"local","tooltip":"","x":670,"y":300,"wires":[[]]},{"id":"ac7596c1.99aee","type":"exec","z":"1591fded.581fe2","command":"Video Capture","addpay":false,"append":"/usr/bin/raspivid -t 30000 -w 570 -h 570 -fps 25 -b 1200000 -p 0,0,570,570 -o /tmp/video.h264","useSpawn":"false","timer":"90","oldrc":false,"name":"","x":700,"y":240,"wires":[["ee9b8c23.f45c4"],["ee9b8c23.f45c4"],["ee9b8c23.f45c4"]]},{"id":"ee9b8c23.f45c4","type":"debug","z":"1591fded.581fe2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":880,"y":180,"wires":[]},{"id":"6080d6c0.890608","type":"ui_group","z":"","name":"Camera","tab":"91b245b1.b4ed7","order":9,"disp":true,"width":"17","collapse":false},{"id":"2db625cf.759fb2","type":"ui_group","z":"","name":"CPU Temperature","tab":"4802b223.98b354","order":1,"disp":true,"width":30,"collapse":false},{"id":"91b245b1.b4ed7","type":"ui_tab","z":"","name":"Pump Control Dashboard","icon":"dashboard","order":3,"disabled":false,"hidden":false},{"id":"4802b223.98b354","type":"ui_tab","z":"","name":"Proelian Server","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Its as if node-red doesn't have permission to access the camera. I checked and it should.
Can you open a terminal and stop and restart node-red and post the startup messages please. You should be able to do that by running
node-red-stop
node-red-start
Is that you you normally run node-red?
1447 sudo systemctl stop nodered.service
1448 sudo systemctl start nodered.service
1449 sudo systemctl status nodered.service
1450 history
pi@proelian:~/.node-red $ !1449
● nodered.service - Node-RED graphical event wiring tool
Loaded: loaded (/lib/systemd/system/nodered.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2020-06-19 08:43:39 PDT; 2min 3s ago
Docs: http://nodered.org/docs/hardware/raspberrypi.html
Main PID: 23615 (node)
Tasks: 14 (limit: 4915)
Memory: 87.6M
CGroup: /system.slice/nodered.service
├─23615 node-red
├─23650 python -u /home/pi/.node-red/node_modules/pi-plates/plate_io.py
├─23658 python -uc import os import json import sys if sys.version_info[0]<3: channel = os.fdopen(3, "r+") else: channel = os.
└─23662 python -uc import os import json import sys if sys.version_info[0]<3: channel = os.fdopen(3, "r+") else: channel = os.
I want to see the node red startup log please. node-red-start should do that assuming you installed using the recommended technique.
Node Red is run as a service on a Raspberry Pi 4 running "LATEST" code Buster/Debian
Jun 19 11:17:00 proelian systemd[1]: nodered.service: Succeeded.
Jun 19 11:17:00 proelian systemd[1]: Stopped Node-RED graphical event wiring tool.
Jun 19 11:17:27 proelian systemd[1]: Started Node-RED graphical event wiring tool.
Jun 19 11:17:28 proelian Node-RED[31461]: 19 Jun 11:17:28 - [info]
Jun 19 11:17:28 proelian Node-RED[31461]: Welcome to Node-RED
Jun 19 11:17:28 proelian Node-RED[31461]: ===================
Jun 19 11:17:28 proelian Node-RED[31461]: 19 Jun 11:17:28 - [info] Node-RED version: v1.0.6
Jun 19 11:17:28 proelian Node-RED[31461]: 19 Jun 11:17:28 - [info] Node.js version: v12.18.0
Jun 19 11:17:28 proelian Node-RED[31461]: 19 Jun 11:17:28 - [info] Linux 4.19.118-v7l+ arm LE
Jun 19 11:17:28 proelian Node-RED[31461]: 19 Jun 11:17:28 - [info] Loading palette nodes
Jun 19 11:17:31 proelian Node-RED[31461]: 19 Jun 11:17:31 - [info] Dashboard up and running
Jun 19 11:17:32 proelian Node-RED[31461]: 19 Jun 11:17:32 - [info] +-----------------------------------------------------
Jun 19 11:17:32 proelian Node-RED[31461]: 19 Jun 11:17:32 - [info] | uibuilder initialised:
Jun 19 11:17:32 proelian Node-RED[31461]: 19 Jun 11:17:32 - [info] | root folder: /home/pi/.node-red/uibuilder
Jun 19 11:17:32 proelian Node-RED[31461]: 19 Jun 11:17:32 - [info] | version . .: 2.0.8
Jun 19 11:17:32 proelian Node-RED[31461]: 19 Jun 11:17:32 - [info] | packages . : vue,bootstrap,bootstrap-vue,socket.io,jquery
Jun 19 11:17:32 proelian Node-RED[31461]: 19 Jun 11:17:32 - [info] Dashboard version 2.22.1 started at /ui
Jun 19 11:17:33 proelian Node-RED[31461]: 19 Jun 11:17:33 - [info] Settings file : /home/pi/.node-red/settings.js
Jun 19 11:17:33 proelian Node-RED[31461]: 19 Jun 11:17:33 - [info] Context store : 'default' [module=memory]
Jun 19 11:17:33 proelian Node-RED[31461]: 19 Jun 11:17:33 - [info] User directory : /home/pi/.node-red
Jun 19 11:17:33 proelian Node-RED[31461]: 19 Jun 11:17:33 - [warn] No active project : using default flows file
Jun 19 11:17:33 proelian Node-RED[31461]: 19 Jun 11:17:33 - [info] Flows file : /home/pi/.node-red/flows_proelian.json
Jun 19 11:17:33 proelian Node-RED[31461]: 19 Jun 11:17:33 - [info] Server now running at http://localhost:1880/
Jun 19 11:17:33 proelian Node-RED[31461]: ---------------------------------------------------------------------
Jun 19 11:17:33 proelian Node-RED[31461]: Your flow credentials file is encrypted using a system-generated key.
Jun 19 11:17:33 proelian Node-RED[31461]: If the system-generated key is lost for any reason, your credentials
Jun 19 11:17:33 proelian Node-RED[31461]: file will not be recoverable, you will have to delete it and re-enter
Jun 19 11:17:33 proelian Node-RED[31461]: your credentials.
Jun 19 11:17:33 proelian Node-RED[31461]: You should set your own key using the 'credentialSecret' option in
Jun 19 11:17:33 proelian Node-RED[31461]: your settings file. Node-RED will then re-encrypt your credentials
Jun 19 11:17:33 proelian Node-RED[31461]: file using your chosen key the next time you deploy a change.
Jun 19 11:17:33 proelian Node-RED[31461]: 19 Jun 11:17:33 - [info] Starting flows
Jun 19 11:17:33 proelian Node-RED[31461]: 19 Jun 11:17:33 - [info] [python-function:MCP9808 I2C Inquiry] Python function 'MCP9808 I2C Inquiry' running on PID 31503
Jun 19 11:17:34 proelian Node-RED[31461]: 19 Jun 11:17:34 - [info] [python-function:MCP3428-1] Python function 'MCP3428-1' running on PID 31507
Jun 19 11:17:34 proelian Node-RED[31461]: 19 Jun 11:17:34 - [info] Started flows
Jun 19 11:17:34 proelian Node-RED[31461]: 19 Jun 11:17:34 - [info] serial port /dev/ttyUSB1 opened at 115200 baud 8N1
Jun 19 11:17:34 proelian Node-RED[31461]: 19 Jun 11:17:34 - [info] serial port /dev/ttyUSB0 opened at 115200 baud 8N1
Jun 19 11:17:34 proelian Node-RED[31461]: 19 Jun 11:17:34 - [info] [mqtt-broker:PI] Connected to broker: mqtt://127.0.0.1:1883
I think there is a startup option to bump up the logging.
I turned up debug, stopped, started, and ran command to trigger error.
Jun 19 11:33:57 proelian Node-RED[32133]: 19 Jun 11:33:57 - [info] Stopped flows
Jun 19 11:33:57 proelian systemd[1]: nodered.service: Succeeded.
Jun 19 11:33:57 proelian systemd[1]: Stopped Node-RED graphical event wiring tool.
Jun 19 11:34:02 proelian systemd[1]: Started Node-RED graphical event wiring tool.
Jun 19 11:34:04 proelian Node-RED[32387]: 19 Jun 11:34:04 - [info]
Jun 19 11:34:04 proelian Node-RED[32387]: Welcome to Node-RED
Jun 19 11:34:04 proelian Node-RED[32387]: ===================
Jun 19 11:34:04 proelian Node-RED[32387]: 19 Jun 11:34:04 - [info] Node-RED version: v1.0.6
Jun 19 11:34:04 proelian Node-RED[32387]: 19 Jun 11:34:04 - [info] Node.js  version: v12.18.0
Jun 19 11:34:04 proelian Node-RED[32387]: 19 Jun 11:34:04 - [info] Linux 4.19.118-v7l+ arm LE
Jun 19 11:34:04 proelian Node-RED[32387]: 19 Jun 11:34:04 - [info] Loading palette nodes
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-ads1115 1.2.7
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-ads1115
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-ads7828 1.1.5
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-ads7828
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-ams5812 1.0.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-ams5812
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-ams5915 1.0.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-ams5915
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-comm 1.6.10
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-comm
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-current 1.0.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-current
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-humichip 1.0.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-humichip
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-industrial 1.3.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-industrial
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-mcp23008 1.5.5
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-mcp23008
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-mcp23017 0.1.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-mcp23017
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-mcp3425 1.0.4
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-mcp3425
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-mcp3428 0.1.0
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-mcp3428
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-mcp4725 1.0.4
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-mcp4725
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-mcp4728 1.1.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-mcp4728
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-mlp115a2 1.0.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-mlp115a2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-pca9536 1.1.0
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-pca9536
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: ncd-red-wireless 1.5.18
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/ncd-red-wireless
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-actionflows 2.0.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-actionflows
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-binary 0.1.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-binary
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-buffer-array 1.1.0
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-buffer-array
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-calc 1.0.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-calc
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-calculate 0.1.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-calculate
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-chromecast-session 1.0.4
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-chromecast-session
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-counter 0.1.5
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-counter
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-cpu 0.0.4
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-cpu
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-dashboard-average-bars 0.0.6
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-dashboard-average-bars
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-float 1.0.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-float
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-flow-statistics 0.1.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-flow-statistics
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-graphs 0.3.5
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-graphs
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-gzip 0.0.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-gzip
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-html-to-text 0.0.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-html-to-text
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-i2c 0.6.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-i2c
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-image-output 0.6.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-image-output
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-image-tools 1.3.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-image-tools
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-java-function 0.1.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-java-function
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-modbus 5.13.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-modbus
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-moment2 1.0.5
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-moment2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-nbrowser 1.1.4
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-nbrowser
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-npm 1.0.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-npm
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-pi-plates 0.0.9
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-pi-plates
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-play-audio 2.5.0
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-play-audio
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-python-function 0.0.5
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-python-function
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-say 0.1.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-say
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-sun-position 1.1.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-sun-position
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-suncron 1.4.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-suncron
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-totaliser 0.0.11
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-totaliser
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-ui-actions 0.1.8
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-ui-actions
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-ui-artless-gauge 0.1.45
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-ui-artless-gauge
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-ui-heatmap 2.1.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-ui-heatmap
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-ui-level 0.1.33
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-ui-level
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-ui-media 1.2.0
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-ui-media
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-ui-state-trail 0.3.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-ui-state-trail
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-ui-statechart 0.1.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-ui-statechart
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-ui-value-trail 0.2.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-ui-value-trail
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-uibuilder 2.0.8
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-uibuilder
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-unit-converter 0.0.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-unit-converter
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-vcgencmd 1.0.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-vcgencmd
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-zabbix-sender 1.0.0
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-contrib-zabbix-sender
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-dashboard 2.22.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-dashboard
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-base64 0.2.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-base64
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-email 1.7.8
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-email
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-mysql 0.1.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-mysql
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-openweathermap 0.2.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-openweathermap
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-pi-gpio 1.1.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-pi-gpio
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-ping 0.2.0
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-ping
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-random 0.1.4
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-random
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-rbe 0.2.9
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-rbe
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-serialport 0.10.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-serialport
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-smooth 0.1.2
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-smooth
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-snmp 0.0.24
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-snmp
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-sqlite 0.4.3
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-sqlite
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-tail 0.1.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-tail
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-twitter 1.1.6
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-twitter
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-ui-lineargauge 0.3.6
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-ui-lineargauge
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-ui-list 0.2.5
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-ui-list
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-ui-table 0.3.1
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /home/pi/.node-red/node_modules/node-red-node-ui-table
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-rbe 0.2.8 *ignored due to local copy*
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /usr/lib/node_modules/node-red/node_modules/node-red-node-rbe
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-node-tail 0.1.1 *ignored due to local copy*
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /usr/lib/node_modules/node-red/node_modules/node-red-node-tail
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug] Module: node-red-contrib-python-function 0.0.4 *ignored due to local copy*
Jun 19 11:34:05 proelian Node-RED[32387]: 19 Jun 11:34:05 - [debug]         /usr/lib/node_modules/node-red-contrib-python-function
Jun 19 11:34:07 proelian Node-RED[32387]: 19 Jun 11:34:07 - [info] Dashboard up and running
Jun 19 11:34:08 proelian Node-RED[32387]: 19 Jun 11:34:08 - [info] +-----------------------------------------------------
Jun 19 11:34:08 proelian Node-RED[32387]: 19 Jun 11:34:08 - [info] | uibuilder initialised:
Jun 19 11:34:08 proelian Node-RED[32387]: 19 Jun 11:34:08 - [info] |   root folder: /home/pi/.node-red/uibuilder
Jun 19 11:34:08 proelian Node-RED[32387]: 19 Jun 11:34:08 - [info] |   version . .: 2.0.8
Jun 19 11:34:08 proelian Node-RED[32387]: 19 Jun 11:34:08 - [info] |   packages . : vue,bootstrap,bootstrap-vue,socket.io,jquery
Jun 19 11:34:08 proelian Node-RED[32387]: 19 Jun 11:34:08 - [info] Dashboard version 2.22.1 started at /ui
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] Settings file  : /home/pi/.node-red/settings.js
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] Context store  : 'default' [module=memory]
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] User directory : /home/pi/.node-red
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [warn] No active project : using default flows file
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] Flows file     : /home/pi/.node-red/flows_proelian.json
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] Server now running at http://localhost:1880/
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] loaded flow revision: 878806e6d05c0279648efe6513bf123f
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] red/runtime/nodes/credentials.load : no user key present
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] red/runtime/nodes/credentials.load : using default key
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] red/runtime/nodes/credentials.load : keyType=system
Jun 19 11:34:09 proelian Node-RED[32387]: ---------------------------------------------------------------------
Jun 19 11:34:09 proelian Node-RED[32387]: Your flow credentials file is encrypted using a system-generated key.
Jun 19 11:34:09 proelian Node-RED[32387]: If the system-generated key is lost for any reason, your credentials
Jun 19 11:34:09 proelian Node-RED[32387]: file will not be recoverable, you will have to delete it and re-enter
Jun 19 11:34:09 proelian Node-RED[32387]: your credentials.
Jun 19 11:34:09 proelian Node-RED[32387]: You should set your own key using the 'credentialSecret' option in
Jun 19 11:34:09 proelian Node-RED[32387]: your settings file. Node-RED will then re-encrypt your credentials
Jun 19 11:34:09 proelian Node-RED[32387]: file using your chosen key the next time you deploy a change.
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] Starting flows
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] red/nodes/flows.start : starting flow : global
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] red/nodes/flows.start : starting flow : 6acc9db.7a04264
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] red/nodes/flows.start : starting flow : c3b24910.186f48
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] red/nodes/flows.start : starting flow : ff00b690.4e7c68
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] red/nodes/flows.start : starting flow : 59cf5e6e.f0303
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [debug] [position-config:San Andreas CA] initialize latitude=38.1960298 longitude=-120.6804872 tzOffset=null tzDST=0
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] [python-function:MCP9808 I2C Inquiry] Python function 'MCP9808 I2C Inquiry' running on PID 32426
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] [python-function:MCP3428-1] Python function 'MCP3428-1' running on PID 32430
Jun 19 11:34:09 proelian Node-RED[32387]: 19 Jun 11:34:09 - [info] Started flows
Jun 19 11:34:10 proelian Node-RED[32387]: 19 Jun 11:34:10 - [info] serial port /dev/ttyUSB1 opened at 115200 baud 8N1
Jun 19 11:34:10 proelian Node-RED[32387]: 19 Jun 11:34:10 - [info] serial port /dev/ttyUSB0 opened at 115200 baud 8N1
Jun 19 11:34:10 proelian Node-RED[32387]: 19 Jun 11:34:10 - [info] [mqtt-broker:PI] Connected to broker: mqtt://127.0.0.1:1883
I can't see anything there that might be a problem. As you said earlier it is as if you can't connect to the camera. You haven't got something else connected to it already have you? Perhaps try a reboot and try it before doing anything else.
Other than that I don't know. Maybe ask on a pi forum what might cause that error with raspivid.
No we can run the command as pi and it works. But node-red cant seem to run the command in an exec node. Makes no sense.
And node-red is run as pi user
Remember, I never have an easy problem....
I'm hoping @dceejay sees this and chimes up. :slight_smile:
Maybe I can set logging to see the error. Error code 127 seems ode to me though.
When you run it in a terminal is the display connected to the pi? I wonder if it doesn't work if it is not running in a session with a display. Can you connect to the pi via ssh and run the command like that?
Try adding DISPLAY=:0 to the front of the command, but that is just a wild guess and anyone who knows what they are talking about will probably laugh at the suggestion.
Error code 127 returned, when using the bash shell which is the default on raspberry pi, usually means command not found. Can you use an exec node and see what happens if you give the command ls -ahl /usr/bin/raspivid and what it returns in permissions and all there? A different option is that there's part of the command it can't fully understand or that a file referenced in it can't be found, or a script/library underneath it. With the idea that it works from a script, those sound unlikely as reason.
Oh, and take a look at /tmp/ and see if there's already a video.h264 there, and if so which user owns it, and if the pi user has permission to that file.
Why is Video Capture at the start of the command the exec node is trying to execute?
In this case dash is trying to execute a program/script called Video in your path which it cant find. Shouldn’t your command start with /usr/bin/raspivid or even just raspivid? Am i misunderstanding something here?
nodered actually calls exec scripts with dash not bash right now on raspberry pis as this is what raspberry pi os symlinks from /bin/sh/ and this in turn is what node.js uses.
There is actually a pull request merged already which should change this for the exec node soon and make use of bash if its there as there were a few problems with how node.js child process and dash interacted.
That is the name of the exec node I believe. However, the error Video: not found might indicate that it is trying to run a command called Video for some reason.
@vlturner can you post exactly the flow that generates that error please? Using the </> button.
I thought Video capture was part of the error message, but that explains the exact thing... And the whole Video not found would explain the error 127 because Video is not a known command. Spot on!
Found it:
    "id": "ac7596c1.99aee",
    "type": "exec",
    "z": "1591fded.581fe2",
    "command": "Video Capture",
    "addpay": false,
    "append": "/usr/bin/raspivid -t 30000 -w 570 -h 570 -fps 25 -b 1200000 -p 0,0,570,570 -o /tmp/video.h264",
    "useSpawn": "false",
    "timer": "90",
    "oldrc": false,
    "x": 700,
    "y": 240,
        ["ee9b8c23.f45c4"],
        ["ee9b8c23.f45c4"],
        ["ee9b8c23.f45c4"]
The command in the exec node is Video capture, so it is configured wrong. The parameters/actual command are appended.
For comparison, here's the raspistill command from the same flow:
    "id": "6e5e2f42.183ba8",
    "type": "exec",
    "command": "raspistill",
    "addpay": false,
    "append": "-vs -ex night -w 570 -h 570 -o -",
    "timer": "",
    "oldrc": false,
    "x": 660,
    "y": 120,
        ["4f40679e.837c9"],
which is set up correctly, and does work okay.
No i just tested with an invalid command and it is how i think it was the exec node with this output was actually trying to run the literal command:
Edit as @afelix just also pointed out in the json of the exported flow
Thank you all kind sirs....I think this will be useful for those trying to pull in videos. We do need to write a node to do all this mp4 wrapper stuff and camera options...
Hint...Hint...@dceejay....:wink:
I'm just up to my ears in patent and grant paperwork...
Will know in 8 days as to my chance at $50K
still not a sir
Regardless, to fix it try setting the properties of your raspivid node to match those of your raspistill node. Set the values for command and append correctly and retry, see if it changes.
