I couldn't find a sufficient option for a recent Karaoke project. What I needed was the ability to send the first X messages in Y time period and then drop the rest until the time is up.
I ended up using a function node that I believe should work with the following:
// Define constants for rate limiting
const RATE_LIMIT = 100; // Change this to your desired rate limit
const RESET_TIME_MS = 24 * 60 * 60 * 1000; // 24 hours
// Initialize the message count and the daily reset timestamp in flow context
flow.set('messageCount', flow.get('messageCount', "memoryOnly") || 0, "memoryOnly");
flow.set('dailyResetTimestamp', flow.get('dailyResetTimestamp', "memoryOnly") || Date.now(), "memoryOnly");
// Get the current timestamp
const currentTime = Date.now();
// Get the message count and daily reset timestamp from flow context
const messageCount = flow.get('messageCount', "memoryOnly");
const dailyResetTimestamp = flow.get('dailyResetTimestamp', "memoryOnly");
// Check if it's time to reset the message count
if (currentTime - dailyResetTimestamp >= RESET_TIME_MS) {
flow.set('messageCount', 0, "memoryOnly"); // Reset the count
flow.set('dailyResetTimestamp', currentTime, "memoryOnly"); // Update the reset timestamp
// Increment the message count
flow.set('messageCount', messageCount + 1, "memoryOnly");
// Determine if the message should be allowed or blocked
if (messageCount >= RATE_LIMIT) {
// Block the message
return null;
// Allow the message to pass
Would this make a good suggestion for the core delay node when set to rate limit?
