So the problem I had in the previous post was caused by the API rate limit.
so string to figure out a design for rate limit, after each message I receive back headers X-RateLimit-Reset & X-RateLimit-Limit (Airthings for Business).
Does anyone have any idea?
Here is what i have tried: `
"id": "f300838f7519a85a",
"type": "link in",
"z": "f871c3c06ed134b9",
"name": "http",
"links": [],
"x": 55,
"y": 560,
"f0bc4da034fa8851"
"id": "5bb784d67a54953a",
"type": "switch",
"property": "x-ratelimit-remaining",
"propertyType": "flow",
"rules": [
"t": "lt",
"v": "100",
"vt": "num"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 290,
"y": 560,
"f42159788a0e1452"
"6096b02a49a94961"
"id": "f42159788a0e1452",
"type": "function",
"func": "var o = RED.util.cloneMessage(flow.get('o')) || 0\nvar q = msg.payload\nmsg.url = msg.payload.url \nmsg.method = msg.payload.method\nmsg.headers = msg.payload.headers\nmsg.payload = msg.payload.data\nif (o < 4900){\n // @ts-ignore\n o++ \n flow.set('o',o)\n msg.delay = 0\n return msg\n}\nelse {\n var time = RED.util.cloneMessage(flow.get('x-ratelimit-reset'))\n\n // @ts-ignore\n msg.delay = (time * 1000)- parseInt(Date.now())\n return msg\n}\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 540,
"b698a49fbba89065"
"id": "b698a49fbba89065",
"type": "delay",
"pauseType": "delayv",
"timeout": "5",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 600,
"y": 540,
"428e8c9f431bf3d3"
"id": "4a554b189c583933",
"type": "switch",
"property": "statusCode",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "200",
"vt": "num"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 930,
"y": 580,
"bb7730d81242ae7e"
"cf485a655de75706"
"id": "428e8c9f431bf3d3",
"type": "http request",
"method": "use",
"ret": "obj",
"paytoqs": "ignore",
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"senderr": false,
"x": 770,
"y": 580,
"4a554b189c583933"
"id": "f0bc4da034fa8851",
"type": "function",
"func": "var o = parseInt(RED.util.cloneMessage(flow.get('x-ratelimit-reset')))\nvar e = RED.util.cloneMessage(flow.get('x-ratelimit-reset-old')) || 0\nif (e == 0){\n e = o\n}\n\nif (o<=e){\nreturn msg;\n}\nelse {\n flow.set('x-ratelimt-reset-old',o )\n flow.set('o', 0)\n return msg;\n}\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 160,
"y": 560,
"5bb784d67a54953a"
"id": "cf485a655de75706",
"type": "link out",
"mode": "return",
"links": [],
"x": 1235,
"y": 580,
"id": "6096b02a49a94961",
"type": "function",
"func": "msg.url = msg.payload.url\nmsg.method = msg.payload.method\nmsg.headers = msg.payload.headers\nmsg.payload = msg.payload.data\n\nflow.set('o',0)\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 580,
"428e8c9f431bf3d3"
"id": "bb7730d81242ae7e",
"type": "function",
"func": "\nflow.set('x-ratelimit-remaining', parseInt(msg.headers['x-ratelimit-remaining']))\nflow.set('x-ratelimit-reset', msg.headers['x-ratelimit-reset'])\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1080,
"y": 560,
"cf485a655de75706"
