I'm trying to re-install node-red-dashboard as the artless gauge node didn't show on the ui and I just started to explore the idea of a home automation dashboard on Node-RED so not much "production code" yet.
Have removed all nodes relating to node-red-dashboard but when I go to the palette manager it says node-red-dashboard "in use" and no option to re-install or remove. Do I have to disable all nodes first before I can continue?
How do I get out of this dead end?
FYI, Node-RED is running on IBM Cloud
