Hello. i would like to separate and open the xml file that is attached to an email.
I would like to send myself the measured values from a cloud as an email with an attached xml attachment from an email address and query them with nodered. I would like to read the values from the xml file in the attachment
What have you tried? Where are you up to? Are you getting emails into your node-red? Have you inspected the email with debug nodes?
Hello Steve,
i would like to send data from an inventory management software (filling levels/consumption etc) by mail with XML (measured values) attachment to a gmail address. from there i would like to read the xml attached to the mail. so i would have an easy way to subscribe to the data from the cloud without going through an API. the subscribed data can then be made available e.g. in a gateway locally to a controller via Modbus or OPC UA
Assuming there is only ever one XML attachement:
Pass the msg through an XML node set up like this:
Send it to a debug node - what do you see?
Hopefully you see the XML nicely parsed into an object where you can access any part of the data you need to.
TIP
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
