I am stuck on how to read a XML file on real time using NODE RED I will attach the XML file if its needed
What have you tried so far?
What do you mean by this?
I have data in XML file so i need to present it as chart by using NOD RED
there experiment is this article so i need the code of it .
Low-Cost Precision Monitoring System of Machine Tools for SMEs
kanglin Xing
Yes, you said that already.
What part are you stuck on?
- have you managed to read the XML into node-red?
- have you managed to convert the XML to JS Object?
- Have you got anything showing in chart?
I guess you mean this article? I dont think the author is on this forum & that article doesnt seem to have any attachments
Yes brother so what  can i have to do?
I need this experiment code to compare it with my experiment
I have you managed to read the XML into node-red by using C# but i need to compare with node red
Sorry but what you are saying makes no sense.
An XML file can be read directly by Node-RED using the core file-in and XML nodes. But what that has to do with "compare with Node-RED", we can't understand. If you mean that you want to compare two different versions of an XML file, that would make sense - is that what you are trying to do?
