Read and set .flow or .global typed input correctly
Hi
I use a typed input to let the user chose a context store:
I then get this as the value of the input:
#:(file)::myNode
Strange format to me but ok (any background info?).
But how can I set the typed input to that state - context and store? This is my result so far, not what I expect:
This is a bug in 2.1.1... fixed in 2.1.2
It has always used the 'strange' #:... syntax to encode the context store name into the property. But a bug in 2.1.0/1 meant it exposed it to the end user rather than keep it a hidden internal detail.
Hi Nick, thank you for the fast reply.
I'm currently using 2.0.5. The 'bug' then could be older.
So the intended behavior is that
input.typedInput('value','#:(file)::myNode');
should result into this
And voila, after updating to 2.1.2 it works as intended!
Thank you for pointing me in to the right direction.
Chris
