I would like to read a value in SQL server and write it to a Rockwell PLC.
With "Inject" node it was possible to write, now I would like to reade (SQL) an write to PLC.
Thanks.
Thanks.
Put a SQL Node (I recommend node-red-contrib-mssql-plus) between the inject and the and the PLC node.
Use a change node or function node to format the SQL data into the correct payload format.
Thank you Steve-Mcl, I tried to reproduce what you said but I think I did some wrong configuration in the change node.
"id": "e441ea33b0e8edbf",
"type": "tab",
"label": "DnA_Prediction",
"disabled": false,
"info": "",
"env": []
"id": "c34001de6df9fa2b",
"type": "eth-ip out",
"z": "e441ea33b0e8edbf",
"endpoint": "31600212ce3ff55f",
"variable": "TesteDnA",
"program": "",
"name": "TesteDnA1",
"x": 310,
"y": 240,
"id": "e46b4da53d6e058b",
"type": "MSSQL",
"mssqlCN": "30fec03c812ee923",
"name": "DnA_SP",
"query": "SELECT TOP 1 Afinagem \nFROM [DnA].[dbo].[Banco_Secador_SP]",
"outField": "payload",
"x": 260,
"y": 360,
"a96578912e68c0cb"
"id": "e4f47ce9a8bfe538",
"type": "debug",
"name": "debug 8",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 220,
"y": 620,
"id": "a96578912e68c0cb",
"type": "change",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "payload[0].Afinagem",
"fromt": "str",
"to": "",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 230,
"y": 480,
"e4f47ce9a8bfe538"
"id": "79d3c146a55e631f",
"type": "inject",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "SELECT TOP 1 Afinagem FROM [DnA].[dbo].[Banco_Secador_SP]",
"payloadType": "str",
"x": 90,
"y": 300,
"e46b4da53d6e058b"
"id": "31600212ce3ff55f",
"type": "eth-ip endpoint",
"address": "192.168.155.28",
"slot": "0",
"cycletime": "5000",
"name": "TesteDna",
"vartable": {
"TesteDnA": {
"type": "REAL"
"id": "30fec03c812ee923",
"type": "MSSQL-CN",
"name": "Dryer_DnA_SP",
"server": "KPISERVER\\SSA",
"encyption": false,
"database": "Dna"
