Reading data from MSSQL for a date range using DatePicker
Hi, Im having problem when reading data from MSSQL. I can't get the SQL statement right and get this error always. I did try to change the format type to the same as MSSQL, but it didn't work.
this is my flow:
flows.json (7.1 KB)
You have created an ISO8601 timestamp format which is incorrect for MSSQL. Correct format for MSSQL is 'YYYY-MM-DD HH:MM:SS', e.g. '2022-12-09 12:34:56'.
I did try, but still get the same error
No you haven't - check that date string again, it is not 'YYYY-MM-DD HH:MM:SS', it is 'YYYY-MM-D H:M:S'
I try again, and this is the result
I'm wrong in using flow variable, it works now with your suggest, thank you!
