i'm using a watch node for checking if there are changes in file. This works if i open a file and save it's contents manually.
But the problem lies with the fact when a siemens comfort panel is writing it's log over the ethernet to the file the file is overwritten but it's only changes it's modify date if i select the file(doesn't even have to open the file). So is there another way to read the modified time that's trigger the file?
Thanks at advance!
Kind regards,
Ward
