I tried this before. But with no succes.
If I got that right, it should actually work with this flow?! But I did not receive the response of the bulb in Node Red (but in the MQTT-Broker Logs).
Do you have any ideas how I can catch the respone in NodeRed?
This is my Flow:
"id": "3523f9f6631a492f",
"type": "tab",
"label": "Bulb repsonse",
"disabled": false,
"info": "",
"env": []
"id": "3fd60f1c8f78b190",
"type": "debug",
"z": "3523f9f6631a492f",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 550,
"y": 300,
"id": "785215765a426f6f",
"type": "inject",
"name": "Statusabfrage ",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "{\"brightness\": \"\"}",
"payloadType": "str",
"x": 350,
"y": 220,
"d9259d47693d1f8b",
"abe33dd859ac5def"
"id": "f2e34ef30cecf719",
"type": "mqtt in",
"topic": "zigbee2mqtt/Lampe_Buero",
"qos": "0",
"datatype": "json",
"broker": "5f7aaa48051ef5f8",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 270,
"y": 280,
"3fd60f1c8f78b190"
"id": "d9259d47693d1f8b",
"type": "mqtt out",
"topic": "zigbee2mqtt/Lampe_Buero/get",
"qos": "",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"x": 610,
"y": 220,
"id": "abe33dd859ac5def",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"x": 570,
"y": 160,
"id": "5f7aaa48051ef5f8",
"type": "mqtt-broker",
"name": "mosquitto mit PW",
"broker": "mosquitto",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
