RED.plugins.registerPlugin is not called
Hi
I have developed a simple plugin, the associated js file is never called although the associated html file is loaded.
Therefore the code I have for RED.plugins.registerPlugin seems to be never triggered:
myplugin.js:
module.exports = async function (RED) {
        RED.httpAdmin.post('/test', RED.auth.needsPermission('notify.write'), async function (req, res) {
    RED.plugins.registerPlugin('myplugin', { type: 'myplugin',
        onadd: function() {
            console.log('plugin added')
package.json
"node-red": {
    "version": ">=3.1.0",
    "plugins": {
      "myplugin": "myplugin.js"
ADMIN EDIT: Use code blocks for code
You seem to have a mix of client side code and server side logic.
See this gist: Example Node-RED that adds a sidebar panel in the editor · GitHub
