Hi everyone!
I'm still relatively new to Node-RED and I’ve hit a roadblock in a project. I’m hoping someone here can help me figure it out.
I'm trying to automate the redeployment of flows through the Node-RED API. Initially, I had a containerized setup with no authentication enabled. Everything worked as expected: I would click an inject node, and it would trigger the flow redeployment. The flow I’m using is included below.
However, the issue started when I enabled authentication. I updated my settings.js to include adminAuth, and while the login screen works fine, the redeployment flow has stopped working. The inject node no longer seems to trigger the actual redeployment, and I don’t see the expected message in the debug node.
I’ve tried various changes and troubleshooting steps, but nothing seems to resolve it.
(trying to turn off API authentication and using allowed IP's restriction and trying to pass the login info in the http request node)
Has anyone run into this issue before? How should I modify the flow to work with authentication enabled?
Thanks in advance for your help!
"id": "fd211699eeb8a572",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "09597665314e9c08",
"type": "inject",
"z": "fd211699eeb8a572",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 540,
"y": 280,
"1d43688fa058eb14"
"id": "b8f5e6151ca3bd0d",
"type": "comment",
"name": "Redeploy!",
"info": "",
"x": 780,
"y": 240,
"id": "1d43688fa058eb14",
"type": "delay",
"pauseType": "delay",
"timeout": "500",
"timeoutUnits": "milliseconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 690,
"y": 280,
"e220e37a36fa10e6"
"id": "e220e37a36fa10e6",
"type": "function",
"name": "Redeployer",
"func": "// Set the API endpoint\nmsg.url = \"http://localhost:1880/flows\";\nmsg.method = \"POST\";\n\n// Headers required for a reload deploy\nmsg.headers = {\n \"Content-Type\": \"application/json; charset=utf-8\",\n \"Node-RED-Deployment-Type\": \"reload\", // triggers a \"Restart Flows\" deploy\n \"Node-RED-API-Version\": \"v2\"\n};\n\n// Minimal payload (flows are reloaded from disk)\nmsg.payload = { \"flows\": [{}] };\nnode.warn(\"Changes have been made! This Flow has been redeployed!\");\n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 850,
"y": 280,
"b6204eeabb2d0ef2"
"id": "b6204eeabb2d0ef2",
"type": "http request",
"method": "use",
"ret": "obj",
"paytoqs": "ignore",
"url": "http://localhost:1880/flows",
"tls": "",
"persist": false,
"proxy": "",
"insecureHTTPParser": false,
"authType": "basic",
"senderr": false,
"headers": [],
"x": 1010,
"y": 280,
"id": "5ba406237e18f855",
"type": "debug",
"name": "debug 1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 860,
"y": 480,
"id": "a77ba310b37858fe",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"x": 710,
"y": 480,
"5ba406237e18f855"
