yesterday I have made a fatal mistake which broke my node red (again ).
I have copied couple of nodes between two machines running node red.
unfortunately this broke node red and removing npm, node js, deleted home folder and reinstalling everything (but not wiping system completely) didn't help.
basically there must be a reference to a sensor saved somewhere on the system and it keeps remembering that sensor ID and every time, even after reinstalling NR gives this error:
ReferenceError: node is not defined
and in console im getting this: Mar 10:15:05 - [error] [xiaomi-ht:testu] ReferenceError: node is not defined
is there a way of completely wiping all stuff node-red related so i can start fresh without wiping the system?
You certainly did not need to do all that to fix the problem, whatever it is. Show us the startup log from node red, it starts with the Welcome to node-RED message.
Also tell us what operating system/hardware you are running on and how you installed it.
I am currently running NR on debian stretch 64 bit, with latest npm and node js version 10.15.2 lts.
heres the output from startup:
Starting as a systemd service.
2 Mar 10:51:26 - [info]
Welcome to Node-RED
2 Mar 10:51:26 - [info] Node-RED version: v0.19.6
2 Mar 10:51:26 - [info] Node.js version: v10.15.2
2 Mar 10:51:26 - [info] Linux 4.9.0-8-amd64 x64 LE
2 Mar 10:51:27 - [info] Loading palette nodes
2 Mar 10:51:27 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
2 Mar 10:51:27 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
2 Mar 10:51:27 - [warn] ------------------------------------------------------
2 Mar 10:51:27 - [warn] [node-red-contrib-mi-sensors/xiaomi-yeelight] Error: /home/bednarz/.node-red/node_modules/node-red-contrib-mi-sensors/dist/nodes/yeelight/index.html does not exist
2 Mar 10:51:27 - [info] Settings file : /home/bednarz/.node-red/settings.js
2 Mar 10:51:27 - [info] Context store : 'default' [module=memory]
2 Mar 10:51:27 - [info] User directory : /home/bednarz/.node-red
2 Mar 10:51:27 - [warn] Projects disabled : editorTheme.projects.enabled=false
2 Mar 10:51:27 - [info] Flows file : /home/bednarz/.node-red/flows_debian.json
your credentials.
2 Mar 10:51:27 - [info] Starting flows
2 Mar 10:51:27 - [info] [xiaomi-gateway out:hub] udp.status.ready-nolocal
2 Mar 10:51:27 - [info] Started flows
2 Mar 10:51:27 - [info] [xiaomi-gateway in:hub] udp.status.listener-at
2 Mar 10:51:27 - [info] [xiaomi-gateway in:hub] udp.status.mc-group
2 Mar 10:51:27 - [info] Server now running at http://127.0.0.1:1880/
and it runs fine with other sensors, that are added, but this one particular that causes issues - does not work. sensor itself does work and also runs fine on my other node red system.
Further, you say you want to wipe all node-red related stuff so you can start afresh, but presumably after you deleted your home folder and started again, when you first ran node-red you did not see the problem. If so then what good will uninstalling node-red do?
Hi Colin, thank you for your replies and your time. After wiping home folder out as well as removing npm/node js and starting fresh - I can see the error coming up.
It is only with this sensor, and that very same sensor works on my other instance of node-red on raspi.
I am in the middle of setting up VM just for node-red which I will be able to regularly back up, hope this will be best.
If you wiped your home folder then it should have started with an empty flow. So you should not get the errors. The xaomi node will not even be installed.
Delete the .node-red folder /home/bednarz/.node-red (or rename it in case you want it back) and restart node-red. See what it shows in the log then. Post that log here if necessary. Note that it will be different the first time as it should show it creating an empty flows file.
I have already done that and that one sensor did not work. I have also wiped that drive and setup windows with VM with Debian. That way will be easier to backup and restore.
