Further, you say you want to wipe all node-red related stuff so you can start afresh, but presumably after you deleted your home folder and started again, when you first ran node-red you did not see the problem. If so then what good will uninstalling node-red do?
Colin
7
Related topics
| Cannot access node-red | 35 | 15885 | 6 December 2018 | |
| Fail to remove node that crashes Node Red on start | 8 | 1287 | 17 January 2019 | |
| Node-red stopped working? | 85 | 9785 | 5 June 2019 | |
| Opening node-red | 54 | 2029 | 4 February 2021 | |
| node-RED won't start, Failed with result 'exit-code' | 28 | 5827 | 13 July 2022 |
