I have included the next.js and next.css files as follows:
I verified that the assets/nextjs/next.js file is available in the correct location.
The topology rendering function (initializeTopology) is called in the mounted() lifecycle hook of my Vue.js component.
        "id": "727eb203886b4836",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "30a0758880701ddd",
        "type": "ui-template",
        "z": "727eb203886b4836",
        "group": "3c3c128a73088cb0",
        "page": "",
        "ui": "",
        "name": "topo_trial",
        "order": 1,
        "width": "11",
        "height": "6",
        "head": "",
        "format": "<template>\n    <div>\n        <!-- <p>hello</p> -->\n        <div class=\"msg\">\n            <!-- {{ msg.payload }} -->\n            <div id=\"topology-container\"></div>\n        </div>\n        <link rel=\"alternate icon\" href=\"./favicon.ico\" type=\"image/png\" sizes=\"16x16\">\n        <link rel=\"stylesheet\" href=\"assets/nextjs/next.css\">\n    </div>\n\n</template>\n<script src=\"https://cdn.jsdelivr.net/npm/nextlibs/nx.min.js\"></script>\n<script src=\"assets/nextjs/next.js\"></script>\n<script>\n    export default {\n        data() {\n            return {\n                topologyData: {\n                    nodes: [\n                        { id: 0, x: 400, y: -100, name: \"ISP1\", device_type: \"cloud\", color: \"grey\" },\n                        { id: 1, x: 600, y: -100, name: \"ISP2\", device_type: \"cloud\", color: \"grey\" },\n                        { id: 2, x: 400, y: 0, name: \"Edge1\", device_type: \"router\", color: \"red\" },\n                        { id: 3, x: 600, y: 0, name: \"Edge2\", device_type: \"router\", color: \"red\" },\n                        { id: 4, x: 400, y: 100, name: \"Switch1\", device_type: \"switch\" },\n                        { id: 5, x: 600, y: 100, name: \"Switch2\", device_type: \"switch\" },\n                        { id: 6, x: 200, y: 200, name: \"ESX1\", device_type: \"server\" },\n                        { id: 7, x: 400, y: 200, name: \"ESX2\", device_type: \"server\" },\n                        { id: 8, x: 600, y: 200, name: \"ESX3\", device_type: \"server\" },\n                        { id: 9, x: 800, y: 200, name: \"ESX4\", device_type: \"server\" },\n                        { id: 10, x: 500, y: 300, name: \"SAN\", device_type: \"server\" }\n                    ],\n                    links: [\n                        { source: 0, target: 2, color: \"green\" },\n                        { source: 1, target: 3 },\n                        { source: 2, target: 4, color: \"green\" },\n                        { source: 2, target: 5 },\n                        { source: 3, target: 4 },\n                        { source: 3, target: 5 },\n                        { source: 4, target: 5 },\n                        { source: 6, target: 4, color: \"green\" },\n                        { source: 6, target: 5, color: \"red\" },\n                        { source: 7, target: 4, color: \"green\" },\n                        { source: 7, target: 5, color: \"red\" },\n                        { source: 8, target: 4, color: \"green\" },\n                        { source: 8, target: 5, color: \"red\" },\n                        { source: 9, target: 4, color: \"green\" },\n                        { source: 9, target: 5, color: \"red\" },\n                        { source: 10, target: 4, color: \"red\" },\n                        { source: 10, target: 5, color: \"red\" }\n                    ]\n                },\n                topologyApp: null\n            };\n        },\n        mounted() {\n          \n        \n\n           \n                this.initializeTopology();\n            \n        },\n        methods: {\n            initializeTopology() {\n                const { topologyData } = this;\n\n                // Instantiate nx Application\n                const app = new nx.ui.Application();\n\n                // Configuration for topology\n                const topologyConfig = {\n                    width: window.innerWidth,\n                    height: window.innerHeight,\n                    nodeConfig: {\n                        label: \"model.name\",\n                        iconType: \"model.device_type\",\n                        color: \"model.color\"\n                    },\n                    linkConfig: {\n                        linkType: \"straight\",\n                        color: \"model.color\"\n                    },\n                    showIcon: true\n                };\n\n                // Instantiate Topology\n                const topology = new nx.graphic.Topology(topologyConfig);\n                topology.data(topologyData);\n                topology.attach(app);\n\n                // Attach the app to the container\n                app.container(document.getElementById(\"topology-container\"));\n\n                // Save the app reference\n                this.topologyApp = app;\n            }\n        },\n        unmounted() {\n            // Clean up when the component is destroyed\n            if (this.topologyApp) {\n                this.topologyApp.destroy();\n            }\n        }\n    };\n</script>\n\n<style>\n    #topology-container {\n        width: 100%;\n        height: 100%;\n        background-color: #f0f0f0;\n    }\n</style>\n",
        "storeOutMessages": true,
        "passthru": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 280,
        "y": 160,
        "id": "3c3c128a73088cb0",
        "type": "ui-group",
        "name": "topology",
        "page": "7c0feb07efa735af",
        "width": "11",
        "height": "1",
        "order": 1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "7c0feb07efa735af",
        "type": "ui-page",
        "name": "topo",
        "ui": "64fc71361e24a0d0",
        "path": "/page4",
        "icon": "home",
        "layout": "grid",
        "theme": "",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 4,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "64fc71361e24a0d0",
        "type": "ui-base",
        "path": "/dashboard",
        "appIcon": "",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-iframe",
            "ui-control",
            "ui-template",
            "ui-gauge",
            "ui-chart",
            "ui-slider",
            "ui-form",
            "ui-text-input",
            "ui-number-input",
            "ui-file-input",
            "ui-button",
            "ui-button-group",
            "ui-dropdown",
            "ui-radio-group",
            "ui-switch",
            "ui-text",
            "ui-chart",
            "ui-form",
            "ui-number-input",
            "ui-switch",
            "ui-table",
            "ui-gauge",
            "ui-markdown",
            "ui-iframe",
            "ui-tabulator",
            "ui-radio-group",
            "ui-dropdown",
            "ui-button-group",
            "ui-file-input"
        "showPathInSidebar": false,
        "showPageTitle": false,
        "navigationStyle": "icon",
        "titleBarStyle": "fixed"
this is my error
ReferenceError: nx is not defined
at Proxy.initializeTopology (eval at  (index-TznpjNEy.js:241:3017), :3:17)
at Proxy.mounted (eval at  (index-TznpjNEy.js:241:3500), :2:10)
at Proxy.mounted (index-TznpjNEy.js:241:6528)
