Third party node example
Hello
i'm probably miss a small detail, i'm trying to integrate a lib in a custom node for the dashbboard-2 and make it then avaiable.
So i started and was like yeah this should be possible.
Then i got stuck
After i tried a lot of thing i got back to point 0 and tried to get the example to work from github:
However this doesn't work.
it loads fine in the node-red palette, but if i try to render it doesnt work.
i get the message in my broweser log:
index-N5-Kfgx_.js:370 No Vue component found for ui-example - falling back to ui-template
Does someone get the example to work?
Infos:
[info] Node-RED version: v4.0.9
[info] Node.js version: v20.19.0
[info] Windows_NT 10.0.26100 x64 LE
[debug] Module: @flowfuse/node-red-dashboard 1.23.0
Best regards
I suspect that it also does not follow the most recent best practice for developing flowfuse dashboard nodes.
