Fist it is easier if we have the complete json object that kicks the control off.
As with this we can simulate the flow. We also need to know the object in the json you are using for the control.
[{"id":"c6659f37.54b0f","type":"switch","z":"d34f2b9c.b8cc68","name":"Pass ADC3","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"automationhat/analog.3","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":240,"wires":[["e302a3ea.5a404"]]},{"id":"52a09120.1c02c","type":"switch","z":"d34f2b9c.b8cc68","name":"Pass ADC2","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"automationhat/analog.2","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":180,"wires":[["a6c67e7.6351a8"]]},{"id":"664895a7.90a4ac","type":"switch","z":"d34f2b9c.b8cc68","name":"Pass ADC1","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"automationhat/analog.1","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":120,"wires":[["6d665e54.02875"]]},{"id":"6d665e54.02875","type":"link out","z":"d34f2b9c.b8cc68","name":"Tryck/Nivågivare","links":["3b0e5dbd.3083a2"],"x":715,"y":120,"wires":[]},{"id":"a6c67e7.6351a8","type":"link out","z":"d34f2b9c.b8cc68","name":"","links":["6c038886.3ce188","f03f0300.ea4e5","43c08f15.49cb"],"x":715,"y":180,"wires":[]},{"id":"e302a3ea.5a404","type":"link out","z":"d34f2b9c.b8cc68","name":"Reserv","links":[],"x":715,"y":240,"wires":[]},{"id":"eff06e87.5182e","type":"rpi-automation-hat in","z":"d34f2b9c.b8cc68","name":"Analog Automation HAT Inputs","input":false,"analog":true,"x":180,"y":120,"wires":[["c6659f37.54b0f","664895a7.90a4ac","52a09120.1c02c","d632224b1aa31528","a0d8164e914f775c"]]},{"id":"d632224b1aa31528","type":"change","z":"d34f2b9c.b8cc68","name":"","rules":[{"t":"set","p":"payload","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":180,"y":180,"wires":[[]]},{"id":"f2a44d0f8a58e0ea","type":"inject","z":"d34f2b9c.b8cc68","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"payload","payloadType":"flow","x":170,"y":240,"wires":[["664895a7.90a4ac","52a09120.1c02c","c6659f37.54b0f"]]},{"id":"a0d8164e914f775c","type":"debug","z":"d34f2b9c.b8cc68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":410,"y":100,"wires":[]}]
It is also wise if you want a english speaking community to look at your flow, to have the flow in english.
