Hi all ,
I'm developing a simple interface for home automation which has some logic behind , internal updates and calls to AI routines though APIs. I'm having problems probably cause a lack of knowledge in general javascript msg processing and how to avoid msg loops.-
The question is :
· How can I change the input of a dashboard component without get into an endless loop?
Example :
· UI slider for setting the temp of a heater manually.
· UI switch for enable/disable Automode.
· Internal Logic Function : When Automode is ON , a call to AI API will get temperature value and update the output heater , but I also want to update the slider , and this become into a enless loop.
What I tried :
· Keep the status in a State node between UI Dashboard  , and Internal Logic function.
· Use MQTT to subscribe to changes.
Result :
· Allways endless loop or undesired behaviour .-
Thank you in advance .-
Here is the code :
        "id": "f1210038.8be3d",
        "type": "tab",
        "label": "AIDomotics_CONTROL",
        "disabled": false,
        "info": ""
        "id": "635efa24.63c424",
        "type": "ui_switch",
        "z": "f1210038.8be3d",
        "name": "AT HOME",
        "label": "AT HOME",
        "tooltip": "Indicanos si estas en casa.",
        "group": "e30fbbe1.4b2f68",
        "order": 0,
        "width": "2",
        "height": "1",
        "passthru": false,
        "decouple": "false",
        "topic": "athome",
        "style": "",
        "onvalue": "{\"athome\":1}",
        "onvalueType": "json",
        "onicon": "",
        "oncolor": "",
        "offvalue": "{\"athome\":0}",
        "offvalueType": "json",
        "officon": "",
        "offcolor": "",
        "x": 120,
        "y": 280,
                "c3ae7fc7.bb29f",
                "e6699a51.498b18",
                "69d0bdc2.08a544"
        "icon": "font-awesome/fa-male"
        "id": "c8d96722.8c5e58",
        "name": "AUTO MODE",
        "label": "AUTO MODE",
        "tooltip": "",
        "order": 1,
        "width": "2",
        "height": "1",
        "passthru": false,
        "topic": "automode",
        "style": "",
        "onvalue": "{\"automode\":1}",
        "onicon": "",
        "oncolor": "",
        "offvalue": "{\"automode\":0}",
        "officon": "",
        "offcolor": "",
        "x": 140,
        "y": 340,
                "c3ae7fc7.bb29f",
                "e6699a51.498b18",
                "69d0bdc2.08a544"
        "icon": "node-red/cog.svg"
        "id": "c9ae096d.2ceef8",
        "type": "inject",
        "name": "5_MINS_SCHEDULER",
        "topic": "",
        "payload": "scheduller",
        "payloadType": "flow",
        "repeat": "300",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 170,
        "y": 140,
                "aeed1f62.35c4b"
        "id": "aeed1f62.35c4b",
        "type": "http request",
        "d": true,
        "name": "PREDICTOR_API",
        "method": "GET",
        "ret": "obj",
        "paytoqs": false,
        "url": "aidomgw51.local:11000/api/1.0/prediction?time=15",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 470,
        "y": 580,
                "c2d0b145.77584"
        "id": "6850a2dc.88f19c",
        "d": true,
        "name": "SET_TEMPERATURE",
        "method": "POST",
        "ret": "txt",
        "paytoqs": false,
        "url": "10.254.254.1:5000/api/1.0/therm",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 1600,
        "y": 720,
        "id": "c3ae7fc7.bb29f",
        "type": "debug",
        "name": "USER INPUT MONITOR",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "x": 750,
        "y": 260,
        "id": "4563ce00.eb65a",
        "d": true,
        "name": "VENTILATION",
        "method": "POST",
        "ret": "txt",
        "paytoqs": false,
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 1540,
        "y": 840,
        "id": "cf061b07.e64808",
        "d": true,
        "name": "DRY-HUMIDIFY",
        "method": "POST",
        "ret": "txt",
        "paytoqs": false,
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 1580,
        "y": 780,
        "id": "100a5123.6d199f",
        "type": "ui_slider",
        "name": "TEMP SET",
        "label": "SET MANUAL",
        "tooltip": "",
        "order": 2,
        "width": "6",
        "height": "1",
        "passthru": true,
        "outs": "end",
        "topic": "temperature",
        "min": "0",
        "max": "35",
        "step": "0.5",
        "x": 130,
        "y": 460,
                "b1af509c.63849",
                "e6699a51.498b18"
        "id": "2daa4254.3302de",
        "type": "function",
        "name": "THERM_ENCODER",
        "func": "var temperature = parseFloat(msg.payload.temperature);\n\nmsg.payload.temp = 2*temperature.toFixed(0);\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1340,
        "y": 620,
                "6850a2dc.88f19c"
        "id": "8e2bbf11.0cc92",
        "d": true,
        "name": "NOISE_THRESHOLD",
        "method": "POST",
        "ret": "txt",
        "paytoqs": false,
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 1560,
        "y": 960,
        "id": "2cc58dff.6c6332",
        "name": "ECO MODE",
        "label": "ECO MODE",
        "tooltip": "",
        "order": 1,
        "width": "2",
        "height": "1",
        "passthru": false,
        "topic": "ecomode",
        "style": "",
        "onvalue": "{\"ecomode\":1}",
        "onicon": "",
        "oncolor": "",
        "offvalue": "{\"ecomode\":0}",
        "officon": "",
        "offcolor": "",
        "x": 130,
        "y": 400,
                "c3ae7fc7.bb29f",
                "e6699a51.498b18",
                "69d0bdc2.08a544"
        "icon": "node-red/white-globe.svg"
        "id": "c2d0b145.77584",
        "type": "function",
        "name": "AIDOMOTICS_LOGIC",
        "func": "var athome = msg.payload.athome;\nvar automode = msg.payload.automode;\nvar ecomode = msg.payload.ecomode;\nvar temperature = msg.payload.temperature;\n\nvar msg2 = {payload : {}};\n\nif(ecomode ===1)\n{\n    msg.payload.temperature=\"18\";\n    msg2.payload.uitemperature=\"18\";\n    msg2.payload.uiautomode=\"0\";\n}\n\nreturn [msg,msg2];\n",
        "outputs": 2,
        "noerr": 0,
        "x": 760,
        "y": 440,
                "57933940.1d0518",
                "34734116.d2d0ee"
                "da7f3c94.98112"
        "inputLabels": [
            "IN"
        "outputLabels": [
            "GENERAL",
        "id": "6d3315fa.2834ac",
        "type": "ui_gauge",
        "name": "CURRENT TEMP",
        "order": 4,
        "width": "3",
        "height": "3",
        "gtype": "gage",
        "title": "CURRENT TEMP",
        "label": "ºC",
        "format": "{{msg.payload[0].last.toFixed(2)}}",
        "min": "-10",
        "max": "50",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1570,
        "y": 80,
        "wires": [],
        "inputLabels": [
            "last"
        "id": "f5776efb.ffe21",
        "type": "ui_gauge",
        "name": "DESIRED_TEMP",
        "order": 4,
        "width": "3",
        "height": "3",
        "gtype": "gage",
        "title": "DESIRED TEMP",
        "label": "ºC",
        "format": "{{msg.payload.temperature}}",
        "min": "-10",
        "max": "50",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1570,
        "y": 240,
        "id": "b3ac5890.ed3408",
        "d": true,
        "name": "NOTIFICATION",
        "method": "POST",
        "ret": "txt",
        "paytoqs": false,
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 1540,
        "y": 900,
        "id": "55ce0abe.3427f4",
        "type": "influxdb in",
        "influxdb": "ce36c9f.c159138",
        "name": "SENSOR1",
        "query": "SELECT last(temperature) FROM SENSOR1 WHERE time > now() - 1h LIMIT 1",
        "rawOutput": false,
        "precision": "s",
        "retentionPolicy": "",
        "x": 790,
        "y": 80,
                "6d3315fa.2834ac"
        "id": "34734116.d2d0ee",
        "type": "debug",
        "name": "LOGIC MONITOR",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 1030,
        "y": 240,
        "id": "ef3c2d6.a363ed",
        "type": "inject",
        "name": "5_SECONDS_SCHEDULER",
        "topic": "",
        "repeat": "5",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 180,
        "y": 80,
                "55ce0abe.3427f4",
                "6e572061.38222"
        "id": "b1af509c.63849",
        "type": "template",
        "name": "ENCODER",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "{\"temperature\":{{payload}}}",
        "output": "json",
        "x": 330,
        "y": 460,
                "69d0bdc2.08a544"
        "id": "6e572061.38222",
        "name": "SENSOR2",
        "query": "SELECT last(temperature) FROM SENSOR2 WHERE time > now() - 1h LIMIT 1",
        "rawOutput": false,
        "precision": "s",
        "x": 790,
        "y": 140,
                "c361c291.ac2a6"
        "id": "c361c291.ac2a6",
        "type": "ui_gauge",
        "name": "OUTSIDE TEMP",
        "order": 4,
        "width": "6",
        "height": "3",
        "gtype": "gage",
        "title": "OUTSIDE TEMP",
        "label": "ºC",
        "min": "-10",
        "max": "50",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1570,
        "y": 140,
        "wires": [],
        "inputLabels": [
            "last"
        "id": "ff8b7618.fe0c48",
        "type": "function",
        "func": "var temp = parseFloat(msg.payload.temperature);\n\nmsg.payload.temperature = temp.toFixed(1);\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1340,
        "y": 500,
                "f5776efb.ffe21"
        "id": "cbbbee0b.b5173",
        "type": "ui_toast",
        "position": "bottom left",
        "displayTime": "3",
        "highlight": "",
        "sendall": true,
        "outputs": 0,
        "ok": "OK",
        "cancel": "",
        "raw": false,
        "topic": "Notify : ",
        "name": "SCREEN NOTIFICATION",
        "x": 1590,
        "y": 360,
        "id": "82c10355.dd5de",
        "type": "debug",
        "name": "NOTIFICATION MONITOR",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 1300,
        "y": 240,
        "id": "e4e4820a.a71fb",
        "type": "comment",
        "name": "SCHEDULERS",
        "info": "",
        "x": 140,
        "y": 20,
        "id": "f1c68e40.5a044",
        "type": "comment",
        "name": "USER INPUT",
        "info": "",
        "x": 130,
        "y": 200,
        "id": "93290370.5b384",
        "type": "comment",
        "name": "INFLUXDB INPUTS",
        "info": "",
        "x": 790,
        "y": 20,
        "id": "20253cb5.c4b1f4",
        "type": "comment",
        "name": "DASHBOARD",
        "info": "",
        "x": 1550,
        "y": 20,
        "id": "6f2b35e0.0a0f2c",
        "type": "comment",
        "name": "ACTUATORS OUTPUT",
        "info": "",
        "x": 1600,
        "y": 620,
        "id": "d3483f7f.c3d2d",
        "type": "comment",
        "name": "AI INPUTS",
        "info": "",
        "x": 440,
        "y": 520,
        "id": "e6699a51.498b18",
        "type": "function",
        "name": "NOTIFICATIONS_LOGIC",
        "func": "var athome = msg.payload.athome;\nvar automode = msg.payload.automode;\nvar ecomode = msg.payload.ecomode;\nvar aitemp = msg.payload.temperature;\nvar mtemp = msg.payload.mtemperature;\n\nif (athome === 1)\n{\n    msg.payload.notification = {\"text\":\"Wellcome Home! \"}\n}\nif (athome === 0)\n{\n    msg.payload.notification = {\"text\":\"GoodBye !\"}\n}\nif (automode === 1)\n{\n    msg.payload.notification = {\"text\":\"Auto Mode ON\"}\n}   \nif (automode === 0)\n{\n    msg.payload.notification = {\"text\":\"Auto Mode OFF\"}\n}      \nif (ecomode === 1)\n{\n    msg.payload.notification = {\"text\":\"Eco Mode ON\"}\n}   \nif (ecomode === 0)\n{\n    msg.payload.notification = {\"text\":\"Eco Mode OFF\"}\n}   \n\n\nreturn msg\n",
        "outputs": 1,
        "noerr": 0,
        "x": 770,
        "y": 340,
                "5dfab07a.f2751"
        "inputLabels": [
            "IN"
        "outputLabels": [
            "GENERAL"
        "id": "eebca861.150638",
        "type": "template",
        "name": "TO_TEXT",
        "field": "payload",
        "fieldType": "msg",
        "template": "{{payload.notification.text}}",
        "output": "str",
        "x": 1340,
        "y": 340,
                "cbbbee0b.b5173",
                "82c10355.dd5de"
        "id": "5dfab07a.f2751",
        "type": "switch",
        "name": "EMPTYCHECK",
        "property": "payload.notification.text",
        "propertyType": "msg",
        "rules": [
                "t": "nempty"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 1020,
        "y": 340,
                "eebca861.150638"
        "id": "f563c064.2ce2f",
        "type": "debug",
        "name": "CUSTOM",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 740,
        "y": 580,
        "id": "69d0bdc2.08a544",
        "type": "set-shared-state",
        "state": "4a3b385a.53beb8",
        "name": "USER_INPUT",
        "triggerOnInit": true,
        "provideOutput": false,
        "outputs": 0,
        "x": 440,
        "y": 160,
        "id": "34e3358e.39f77a",
        "type": "get-shared-state",
        "x": 430,
        "y": 220,
                "f19d235b.0ff4"
        "id": "57933940.1d0518",
        "type": "function",
        "name": "MSG_SPLITTER",
        "func": "// MQTT Parser\n// This script will extract 6 properties of a JSON Object\n// And generate 6 outputs one with each value\n\nvar temperature = msg.payload.temperature;\nvar humidity = msg.payload.humidity;\nvar co2 = msg.payload.co2;\nvar tvoc = msg.payload.tvoc;\nvar luminosity = msg.payload.luminosity;\nvar noise = msg.payload.noise;\n\nvar msg1 = {payload : {}};\nvar msg2 = {payload : {}};\nvar msg3 = {payload : {}};\nvar msg4 = {payload : {}};\nvar msg5 = {payload : {}};\nvar msg6 = {payload : {}};\n\nmsg1.payload.temperature = temperature;\nmsg2.payload.humidity = humidity;\nmsg3.payload.co2 = co2;\nmsg4.payload.tvoc = tvoc;\nmsg5.payload.luminosity = luminosity;\nmsg6.payload.noise = noise;\n\nreturn [msg1,msg2,msg3,msg4,msg5,msg6];",
        "outputs": 6,
        "noerr": 0,
        "x": 1010,
        "y": 440,
                "ff8b7618.fe0c48",
                "2daa4254.3302de"
        "id": "f19d235b.0ff4",
        "type": "mqtt out",
        "name": "CONTROL",
        "topic": "control/ui/",
        "qos": "",
        "retain": "true",
        "broker": "6c7acc8b.c658b4",
        "x": 630,
        "y": 200,
        "id": "1f562d2b.d910f3",
        "type": "mqtt in",
        "name": "CONTROL",
        "topic": "control/ui/#",
        "qos": "2",
        "datatype": "json",
        "x": 490,
        "y": 680,
                "c2d0b145.77584"
        "id": "da7f3c94.98112",
        "type": "template",
        "name": "DECODER",
        "field": "payload",
        "fieldType": "msg",
        "template": "{{payload.uitemperature}}",
        "output": "str",
        "x": 210,
        "y": 560,
                "f563c064.2ce2f",
                "534590c8.509e8"
        "id": "534590c8.509e8",
        "type": "delay",
        "pauseType": "delay",
        "timeout": "50",
        "timeoutUnits": "milliseconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "x": 170,
        "y": 660,
        "id": "e30fbbe1.4b2f68",
        "type": "ui_group",
        "z": "",
        "name": "AIDomotics",
        "tab": "3db010d0.9406c",
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "ce36c9f.c159138",
        "type": "influxdb",
        "z": "",
        "hostname": "10.254.254.1",
        "port": "8086",
        "protocol": "http",
        "database": "wisedomdb",
        "usetls": false,
        "tls": ""
        "id": "4a3b385a.53beb8",
        "type": "shared-state",
        "z": "",
        "lbl": "",
        "tags": "",
        "historyCount": "4",
        "dataType": "obj",
        "boolType": "bool",
        "boolStrTrue": "",
        "boolStrFalse": "",
        "precision": "",
        "numMin": "",
        "numMax": "",
        "unit": ""
        "id": "6c7acc8b.c658b4",
        "type": "mqtt-broker",
        "z": "",
        "name": "wisedom_gw_51",
        "broker": "10.254.254.1",
        "port": "1883",
        "clientid": "client1",
        "usetls": false,
        "compatmode": false,
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "willTopic": "",
        "willQos": "0",
        "willPayload": ""
        "id": "3db010d0.9406c",
        "type": "ui_tab",
        "z": "",
        "name": "IoT",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
