Remap msg properties
Yes, in mine.
Yes the complete node red was restarted not long before....
I might try uninstall and reinstall the node.
Shame on me . From palette install window I believed I was using the latest version but it's was not right.
Updated, and now all good.
J.
I made new tests with the remap node.
It works as expected when used individually, but if I use it in a subflow, the list never gets populated from incoming messages....
Does that make sense to you ?
Thanks,
Jerome
Yes - that makes sense - the sub flow instance you edit is not "real" - when you deploy each instance is a copy of the master one, so only they get the live messages, so the editor version never sees them , so cannot populate the dropdown. Maybe use a link call node instead to call it.
I'll add to the docs. Thanks
