String handling remove newline
I am getting out of an exec mode: msg.payload : string[11]
"2498101658↵"
but what I need is: msg.payload : string[10]
"2498101658"
I have tried the string mode without success.
In a function node
msg.payload = msg.payload.trim();
or in a change node
set msg. payload
to JSONata $trim($$.payload)
Thanks,
worked straightaway.
I've learned something.
A better title for your topic maybe String handling remove newline It would help future readers find the solution to a similar issue, String handling is fairly broad.
There is also the " node-red-contrib-string" node if you need to do more-advanced string handling and want to do it in a 'visual' way.
Cheers,
Paul
I did look into every one of the " node-red-contrib-string" methods, including trim right, but did not find any which would remove the return character.
As you suggest, I prefer to do it in a 'visual' way: this is preferable when sharing a flow with somebody who is not familiar with functions or Jsonata.
In order to obtain the string the exec node runs a python script in which I had added a marker word at the end of the string. That done the exec node adds the return character after the marker and I could thereafter remove both marker and return sign with a " node-red-contrib-string".
Somehow messy and leading me to post my question.
The JavaScript trim() function will remove a newline from the end of a string.
Agree, topic title renamed.
