Remove manuel line break from string for msg.payload and switch
Hello everyone,
I am currently working on a flow and I have now encountered the problem that the "exec" function gives me a string that I cannot process in the switch.
I would like to use the function == in the switch. My problem now is that the string I get from the previous function has a manual line break, which I can't copy into the switch.
I have tried everything possible, but I am just too inexperienced with Node Red and don't know how to make it work.
My approaches:
  • Use Slice in a Function (I couldn't get any output)
  • Switch option "contains" (no difference)
Output exec:
Screenshot 2022-04-05 165412
Switch config:
Screenshot 2022-04-05 165434
You can use a function node to trim the payload before the switch
msg.payload = msg.payload.trim();
or use JSONata in the switch property
$trim($$.payload)
Okay wow, that worked perfectly. Thank you very much!
