I think I'm either going nuts or I'm missing something obvious. I have a relay board that returns a string 0 or 1 based on the relay state. I'm trying to convert the "int" to on/off and pass it as the payload to a switch.
For some reason I can't get the function node to convert this correctly.
Function Node:
Output from the exec node that is passed to the function node above:
Hard to tell with those screen shots & without seeing the whole flow i can only guess. Perhaps msg.payload has a newline or other non printable character in it? - meaning msg.payload != "0"
e.g...
You could try trimming before checking...
var pl = msg.payload.trim()
if(pl == "0" )
msg.payload = "off"
else if(pl == "1" )
msg.payload = "on"
EDIT...
if necessary, check payload is a string before calling trim
e.g.
if(typeof msg.payload == "string")
// ok, its a string - to a trim()
Trim did it. I knew it was something simple I was missing. Thanks
