Rename flow file - Need to rename credential file too?
I am running Node-Red in a raspberry without the project features enabled. For a particular reason, I want to rename the flow file from flows_raspberrypi.json to flows.json
I will change settings.js by uncommenting line below:
    // The file containing the flows. If not set, it defaults to flows_<hostname>.json
    //flowFile: 'flows.json',
My question: the credentials file seems to use the computer name in its file name as it appears as flows_raspberrypi_cred.json
Should I rename the credentials file too ?
node-red-configuration-files
Thank you mates !
The credentials file must match your flow file - just with the _cred bit added.
If you rename one, you must rename the other.
Perfect, thank you very much Nick.
