Repeated question but still lost.with infinity loop
so guys i have been trying to set up a cloud version of node red to change things with mqtt like my original node red on my local system.
the information I am trying to change is “target Temp”
I have (ui) dashboard on local node red and i have dashboard 2.0 on my cloud node red.
I am trying to use a slider bar to select a “temp target” in the cloud-red. I expect it to change the local-red slider bar to the said value and change the settings of my tank.
I am bassically want to be able to set a target temp on my local red, and have that change reflected on my cloud red. and vise versa.
[     {         "id": "5354a27f44d76d31",         "type": "group",         "z": "53fbbbc4f29dea55",         "name": "HLT TEMP CONTROLS",         "style": {             "label": true         },         "nodes": [             "3c2d2089173fb786",             "413a524bc796db15",             "c1f634398a44b355",             "9d1d9cd694a85213",             "05024575feb8cdd3",             "6f1c1408184702ef",             "33be77d43280d967",             "032c748e5c64894c",             "902f1cbb8b1844d4",             "25271a56482f17c3",             "0c0d08c5dd17942f",             "56887d1ff63239b6",             "836c7edad4664a45",             "30bfd5eeed43e92e",             "0c83aad05cda059e",             "6c7c64bf3436e71e",             "a0744809ca529231",             "0fafebc7c299f4cc",             "a30d155f773bc0df",             "46215a8381502597",             "4a5956d111869219",             "96e15e010d1f520e",             "c97f9d647c40a57f",             "bd6931c3237e92be"         ],         "x": 74,         "y": 59,         "w": 1302,         "h": 322     },     {         "id": "3c2d2089173fb786",         "type": "link in",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "link in 7",         "links": [             "ac45d488c9472366"         ],         "x": 245,         "y": 120,         "wires": [             [                 "413a524bc796db15",                 "a0744809ca529231"             ]         ]     },     {         "id": "413a524bc796db15",         "type": "change",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "set payload to Temperature value",         "rules": [             {                 "t": "move",                 "p": "payload.DS18B20.Temperature",                 "pt": "msg",                 "to": "payload",                 "tot": "msg"             }         ],         "action": "",         "property": "",         "from": "",         "to": "",         "reg": false,         "x": 450,         "y": 120,         "wires": [             [                 "05024575feb8cdd3",                 "9d1d9cd694a85213",                 "c1f634398a44b355",                 "0fafebc7c299f4cc"             ]         ]     },     {         "id": "c1f634398a44b355",         "type": "ui_template",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "group": "86e793b3a9ac3722",         "name": "HLT",         "order": 3,         "width": 6,         "height": 6,         "format": "<div id=\"{{'gauge_'+$id}}\" class=\"g-container\"\n    style=\"--gauge-value:0; --container-size:6; --gn-distance:14; --ga-tick-count:11; --ga-subtick-count:22; --g-unit:''°F'\">\n    <div id=\"bgr\" class=\"g-body\">\n        <div class=\"g-ring\">\n            <div class=\"g-rivets\">\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n                <div class=g-rivet></div>\n            </div>\n            <div class=\"g-plate\">\n                <div class=\"g-ticks\">\n                    <div class=\"g-tick\" style=\"--ga-tick:1;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:2;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:3;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:4;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:5;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:6;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:7;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:8;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:9;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:10;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:11;\"></div>\n                    <div class=\"g-tick\" style=\"--ga-tick:12;\"></div>\n                </div>\n                <div class=\"g-ticks\">\n                    <div class=\"g-subtick\" style=\"--ga-tick:2;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:4;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:6;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:8;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:10;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:12;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:14;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:16;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:18;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:20;\"></div>\n                    <div class=\"g-subtick\" style=\"--ga-tick:22;\"></div>\n\n                </div>\n                <div class=\"g-nums\">\n                    <div class=\"g-num\" style=\"--ga-tick:1;\">0</div>\n                    <div class=\"g-num\" style=\"--ga-tick:2;\">20</div>\n                    <div class=\"g-num\" style=\"--ga-tick:3;\">40</div>\n                    <div class=\"g-num\" style=\"--ga-tick:4;\">60</div>\n                    <div class=\"g-num\" style=\"--ga-tick:5;\">80</div>\n                    <div class=\"g-num\" style=\"--ga-tick:6;\">100</div>\n                    <div class=\"g-num\" style=\"--ga-tick:7;\">120</div>\n                    <div class=\"g-num\" style=\"--ga-tick:8;\">140</div>\n                    <div class=\"g-num\" style=\"--ga-tick:9;\">160</div>\n                    <div class=\"g-num\" style=\"--ga-tick:10;\">180</div>\n                    <div class=\"g-num\" style=\"--ga-tick:11;\">200</div>\n                    <div class=\"g-num\" style=\"--ga-tick:12;\">220</div>\n\n                </div>\n                <div class=\"g-label\"> HLT </div>\n                <div class=\"g-needle\"></div>\n                <div class=\"g-needle-ring\"></div>\n                <div id=\"{{'gauge_val_'+$id}}\" class=\"g-val\"></div>\n            </div>\n        </div>\n    </div>\n</div>\n<script>\n    (function(scope) {\n    let min = 0;\n    let max = 220;\n  scope.$watch('msg', function(msg) {\n    if (msg) {\n      // Do something when msg arrives\n        const val = msg.payload\n        const v = ((val - min) / (max - min)) * 100;\n        document.getElementById('gauge_'+scope.$id).style.setProperty('--gauge-value', v);\n        document.getElementById('gauge_val_'+scope.$id).innerText = val.toFixed(1);\n    }\n   \n  });\n})(scope);\n</script>",         "storeOutMessages": true,         "fwdInMessages": false,         "resendOnRefresh": true,         "templateScope": "local",         "className": "",         "x": 690,         "y": 140,         "wires": [             []         ]     },     {         "id": "9d1d9cd694a85213",         "type": "ui_digital_display",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "HLT",         "group": "86e793b3a9ac3722",         "order": 5,         "width": 3,         "height": 1,         "digits": 5,         "decimals": 1,         "x": 690,         "y": 100,         "wires": []     },     {         "id": "05024575feb8cdd3",         "type": "change",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "",         "rules": [             {                 "t": "set",                 "p": "HLTambient",                 "pt": "global",                 "to": "payload",                 "tot": "msg"             }         ],         "action": "",         "property": "",         "from": "",         "to": "",         "reg": false,         "x": 720,         "y": 180,         "wires": [             [                 "6f1c1408184702ef"             ]         ]     },     {         "id": "6f1c1408184702ef",         "type": "switch",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "",         "property": "HltTarget",         "propertyType": "global",         "rules": [             {                 "t": "lte",                 "v": "HLTambient",                 "vt": "global"             },             {                 "t": "else"             }         ],         "checkall": "true",         "repair": false,         "outputs": 2,         "x": 910,         "y": 140,         "wires": [             [                 "33be77d43280d967"             ],             [                 "032c748e5c64894c"             ]         ]     },     {         "id": "33be77d43280d967",         "type": "change",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "",         "rules": [             {                 "t": "set",                 "p": "payload",                 "pt": "msg",                 "to": "off",                 "tot": "str"             }         ],         "action": "",         "property": "",         "from": "",         "to": "",         "reg": false,         "x": 1060,         "y": 120,         "wires": [             [                 "902f1cbb8b1844d4"             ]         ]     },     {         "id": "032c748e5c64894c",         "type": "change",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "",         "rules": [             {                 "t": "set",                 "p": "payload",                 "pt": "msg",                 "to": "on",                 "tot": "str"             }         ],         "action": "",         "property": "",         "from": "",         "to": "",         "reg": false,         "x": 1060,         "y": 160,         "wires": [             [                 "902f1cbb8b1844d4"             ]         ]     },     {         "id": "902f1cbb8b1844d4",         "type": "change",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "",         "rules": [             {                 "t": "set",                 "p": "topic",                 "pt": "msg",                 "to": "cmnd/HLT/POWER1",                 "tot": "str"             }         ],         "action": "",         "property": "",         "from": "",         "to": "",         "reg": false,         "x": 1230,         "y": 140,         "wires": [             [                 "56887d1ff63239b6"             ]         ]     },     {         "id": "25271a56482f17c3",         "type": "change",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "",         "rules": [             {                 "t": "set",                 "p": "topic",                 "pt": "msg",                 "to": "HltTarget",                 "tot": "str"             }         ],         "action": "",         "property": "",         "from": "",         "to": "",         "reg": false,         "x": 460,         "y": 220,         "wires": [             [                 "0c0d08c5dd17942f"             ]         ]     },     {         "id": "0c0d08c5dd17942f",         "type": "change",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "HLTTarget",         "rules": [             {                 "t": "set",                 "p": "HltTarget",                 "pt": "global",                 "to": "payload",                 "tot": "msg"             }         ],         "action": "",         "property": "",         "from": "",         "to": "",         "reg": false,         "x": 610,         "y": 260,         "wires": [             [                 "c97f9d647c40a57f"             ]         ]     },     {         "id": "56887d1ff63239b6",         "type": "link out",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "HLTOUT",         "mode": "link",         "links": [             "49bf6457f083306b"         ],         "x": 1335,         "y": 140,         "wires": []     },     {         "id": "836c7edad4664a45",         "type": "ui_dropdown",         "z": "53fbbbc4f29dea55",         "d": true,         "g": "5354a27f44d76d31",         "name": "",         "label": "",         "tooltip": "",         "place": "Select option",         "group": "86e793b3a9ac3722",         "order": 7,         "width": 3,         "height": 1,         "passthru": true,         "multiple": false,         "options": [             {                 "label": "BOIL",                 "value": "215",                 "type": "str"             },             {                 "label": "SANI",                 "value": "190",                 "type": "str"             },             {                 "label": "OFF",                 "value": "1",                 "type": "str"             },             {                 "label": "STRIKE",                 "value": "170",                 "type": "str"             }         ],         "payload": "",         "topic": "target_temperature",         "topicType": "str",         "className": "",         "x": 300,         "y": 220,         "wires": [             [                 "25271a56482f17c3",                 "30bfd5eeed43e92e"             ]         ]     },     {         "id": "30bfd5eeed43e92e",         "type": "ui_digital_display",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "HLT TARGET",         "group": "86e793b3a9ac3722",         "order": 8,         "width": 3,         "height": 1,         "digits": 5,         "decimals": 1,         "x": 520,         "y": 300,         "wires": []     },     {         "id": "0c83aad05cda059e",         "type": "ui_gauge",         "z": "53fbbbc4f29dea55",         "d": true,         "g": "5354a27f44d76d31",         "name": "FERM1",         "group": "25712aa525433650",         "order": 8,         "width": 6,         "height": 6,         "gtype": "gage",         "title": "FERM1 PRESSURE",         "label": "PSI",         "format": "{{msg.payload.psi}}",         "min": 0,         "max": "35",         "colors": [             "#0c00b3",             "#0c00b3",             "#0c00b3"         ],         "seg1": "",         "seg2": "",         "diff": false,         "className": "",         "x": 980,         "y": 260,         "wires": []     },     {         "id": "6c7c64bf3436e71e",         "type": "link in",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "FERM1PRESS",         "links": [],         "x": 815,         "y": 260,         "wires": [             [                 "0c83aad05cda059e"             ]         ]     },     {         "id": "a0744809ca529231",         "type": "debug",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "debug 3",         "active": true,         "tosidebar": true,         "console": false,         "tostatus": false,         "complete": "payload",         "targetType": "msg",         "statusVal": "",         "statusType": "auto",         "x": 360,         "y": 160,         "wires": []     },     {         "id": "0fafebc7c299f4cc",         "type": "debug",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "debug 5",         "active": true,         "tosidebar": true,         "console": false,         "tostatus": false,         "complete": "false",         "statusVal": "",         "statusType": "auto",         "x": 700,         "y": 220,         "wires": []     },     {         "id": "a30d155f773bc0df",         "type": "ui_slider",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "HltTarget",         "label": "slider",         "tooltip": "",         "group": "86e793b3a9ac3722",         "order": 8,         "width": 0,         "height": 0,         "passthru": true,         "outs": "end",         "topic": "HltTarget",         "topicType": "msg",         "min": 0,         "max": "200",         "step": 1,         "className": "",         "x": 200,         "y": 260,         "wires": [             [                 "30bfd5eeed43e92e",                 "4a5956d111869219",                 "bd6931c3237e92be"             ]         ]     },     {         "id": "46215a8381502597",         "type": "link out",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "link out 1",         "mode": "link",         "links": [             "49bf6457f083306b"         ],         "x": 765,         "y": 340,         "wires": []     },     {         "id": "4a5956d111869219",         "type": "debug",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "debug 18",         "active": true,         "tosidebar": true,         "console": false,         "tostatus": false,         "complete": "false",         "statusVal": "",         "statusType": "auto",         "x": 900,         "y": 320,         "wires": []     },     {         "id": "96e15e010d1f520e",         "type": "link in",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "HltTarget",         "links": [],         "x": 115,         "y": 140,         "wires": [             [                 "a30d155f773bc0df"             ]         ]     },     {         "id": "c97f9d647c40a57f",         "type": "link out",         "z": "53fbbbc4f29dea55",         "d": true,         "g": "5354a27f44d76d31",         "name": "hltout",         "mode": "link",         "links": [             "9c88450afc644e8b"         ],         "x": 745,         "y": 260,         "wires": []     },     {         "id": "bd6931c3237e92be",         "type": "rbe",         "z": "53fbbbc4f29dea55",         "g": "5354a27f44d76d31",         "name": "",         "func": "rbe",         "gap": "",         "start": "",         "inout": "out",         "septopics": false,         "property": "payload",         "topi": "topic",         "x": 270,         "y": 340,         "wires": [             [                 "25271a56482f17c3",                 "a30d155f773bc0df"             ]         ]     },     {         "id": "86e793b3a9ac3722",         "type": "ui_group",         "name": "HLT",         "tab": "a74ffe3d.4eb73",         "order": 9,         "disp": true,         "width": "6",         "collapse": false,         "className": ""     },     {         "id": "25712aa525433650",         "type": "ui_group",         "name": "FERMENTER1",         "tab": "a74ffe3d.4eb73",         "order": 13,         "disp": true,         "width": "6",         "collapse": false,         "className": ""     },     {         "id": "a74ffe3d.4eb73",         "type": "ui_tab",         "name": "Brewery",         "icon": "dashboard",         "order": 1,         "disabled": false,         "hidden": false     } ]
above is my local red, below is cloud red
        "id": "1804637663f0b868",
        "type": "group",
        "style": {
            "label": true
        "nodes": [
            "693241b66a23b70b",
            "ac5c7f53a41aae88",
            "8bbf08a8b81d0680",
            "4fccc5df408a654c",
            "8217b067806063ac",
            "6d8e0c2fe372ac46",
            "97e01d75e49e4574",
            "e544b42dfc15cee0",
            "7eb74e8d20fe11ee",
            "db593790dab2d424",
            "7ce76e5c580729e8",
            "9ac1b05def80dd77",
            "487f80a28a943e68",
            "13d8ef630e096c56"
        "x": 164,
        "y": 39,
        "w": 662,
        "h": 522
        "id": "693241b66a23b70b",
        "type": "link in",
        "g": "1804637663f0b868",
        "name": "Hlttemp",
        "links": [
            "ac45d488c9472366"
        "x": 205,
        "y": 160,
                "ac5c7f53a41aae88",
                "8bbf08a8b81d0680"
        "id": "ac5c7f53a41aae88",
        "type": "change",
        "rules": [
                "t": "move",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 340,
        "y": 100,
                "e544b42dfc15cee0"
        "id": "8bbf08a8b81d0680",
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 310,
        "y": 180,
        "id": "4fccc5df408a654c",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "HltTemp",
        "payload": "95",
        "payloadType": "str",
        "x": 600,
        "y": 80,
        "id": "8217b067806063ac",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "HltTemp",
        "payload": "150",
        "x": 600,
        "y": 120,
        "id": "6d8e0c2fe372ac46",
        "type": "link in",
        "links": [
            "b5e19cdc0644d369"
        "x": 245,
        "y": 320,
                "97e01d75e49e4574"
        "id": "97e01d75e49e4574",
        "type": "ui-slider",
        "group": "b0ec6fa10e19fa35",
        "label": "HltTarget",
        "tooltip": "",
        "order": 4,
        "width": 4,
        "height": "2",
        "passthru": false,
        "outs": "end",
        "topic": "topic",
        "topicType": "msg",
        "thumbLabel": "true",
        "showTicks": "always",
        "min": 0,
        "max": "220",
        "step": 1,
        "className": "",
        "iconPrepend": "",
        "iconAppend": "",
        "color": "red",
        "colorTrack": "green",
        "colorThumb": "",
        "showTextField": false,
        "x": 400,
        "y": 460,
                "db593790dab2d424",
                "7eb74e8d20fe11ee",
                "9ac1b05def80dd77",
                "7ce76e5c580729e8"
        "id": "e544b42dfc15cee0",
        "type": "change",
        "name": "HltTemp",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "HltTemp",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 660,
        "y": 220,
                "13d8ef630e096c56"
        "id": "7eb74e8d20fe11ee",
        "type": "link out",
        "mode": "link",
        "links": [
            "49bf6457f083306b"
        "x": 655,
        "y": 520,
        "id": "db593790dab2d424",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 700,
        "y": 380,
        "id": "7ce76e5c580729e8",
        "type": "debug",
        "name": "debug 8",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 720,
        "y": 460,
        "id": "9ac1b05def80dd77",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "HltTarget",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 420,
        "y": 260,
                "487f80a28a943e68",
                "13d8ef630e096c56"
        "id": "487f80a28a943e68",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "HltTarget",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 640,
        "y": 280,
                "97e01d75e49e4574"
        "id": "13d8ef630e096c56",
        "type": "ui-gauge-classic",
        "name": "Hlt",
        "order": 3,
        "width": "4",
        "height": "4",
        "min": 0,
        "max": "220",
        "sectors": [],
        "major_division": "20",
        "minor_division": "1",
        "value_decimal_places": 1,
        "scale_decimal_places": 0,
        "label": "Boil Kettle",
        "measurement": "temperature",
        "units": "°F",
        "needles": [
                "topic": "HltTemp",
                "color": "black",
                "lengthPercent": "100"
                "color": "blue",
                "lengthPercent": "50"
        "hubcolor": "black",
        "sweep_angle": 250,
        "keepwidth": true,
        "myclass": "",
        "x": 740,
        "y": 140,
        "id": "b0ec6fa10e19fa35",
        "type": "ui-group",
        "name": "HLT",
        "page": "a75c75d3958e0e7c",
        "width": 3,
        "height": "6",
        "order": 3,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "a75c75d3958e0e7c",
        "type": "ui-page",
        "name": "Brew_House",
        "ui": "959e0b8c62e485b1",
        "path": "/page1",
        "icon": "home",
        "layout": "grid",
        "theme": "0da5ea2d87210b2f",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "959e0b8c62e485b1",
        "type": "ui-base",
        "name": "My Dashboard",
        "path": "/dashboard",
        "appIcon": "",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "headerContent": "page",
        "navigationStyle": "default",
        "titleBarStyle": "default",
        "showReconnectNotification": true,
        "notificationDisplayTime": 1,
        "showDisconnectNotification": true,
        "allowInstall": true
        "id": "0da5ea2d87210b2f",
        "type": "ui-theme",
        "name": "Default Theme",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094CE",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "density": "default",
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
        "id": "4305f036d565d0de",
        "type": "global-config",
        "env": [],
        "modules": {
            "@flowfuse/node-red-dashboard": "1.26.0",
            "@colinl/node-red-dashboard-2-ui-gauge-classic": "1.4.0"
Try setting the debug to complete message object, you will then see there is a property msg.socketid. If you delete this property then the payload will go to all connected dashboards on all browsers. Leaving socketid and it will only be sent to the dashboard with that socketid.
so i should use a change node to do this.
correct?
Try deleting it with a change node, to see if it works.
that did help with the numbers showing correctly but then i ended up with the infinity loop again
it actuall crashed my dashboard.
i have on pause now. I have the filter nodes in both flows but it still does the infinity loop. it works great for a while and if i hadnt changed anything in a while and change it starts up the infinity loop again. really frustrating, I am obviously missing a crucial step. lol
Is one of your ui nodes set to pass on incoming messages?
yes it is (this is local) and it is also on cloud red. should i remove the pass through on the cloud version? if the local one doesn’t have pass through it doesnt change the temp target setting for the actual temp control.
got it!
  1. deleting “socketid” helps display the new setting temp from external source.(on both local and cloud red)
  2. only having pass through message on local flows. not passing it through on the external source keeps from having infinity loop. with the aid in the filters following the messages.
I believe i have it fixed now ill do a little more testing before i can officially trust it.
just making sure i say thank you E1cid
