Replace a heavily wired node
I have found myself in the situation a few times where I would like to insert a node right before or after a heavily wired node, or the heavily wired node has to be replaced with another node altogether.
Unless my search keywords are wrong, I can't seem to find any way of accomplishing this without having to reconnect all wires manually.
I imagine the ability to Ctrl+Click a node just as the canvas, or to avoid mistake Alt+Del a node and have the node selection menu drop down (allowing a change to another node with wires still attached).
Simplest use case for me would be to take multiple inputs to a node and re-connect them to a no-op node - which is what I often wish I had done to begin with.
I understand that I may be the only idiot who thinks this has merit :laughing:, but why not ask?
shift click is the answer - will move a group of wires in one go
https://nodered.org/docs/user-guide/editor/workspace/wires
I feel silly now that I see the answer, and sorry for posting in feature request first. It did take me a few tries to convert the instructions to use, but absolutely brilliant!
Thank you for the time @dceejay, on to an even better NR experience.
