Replace a JSON value with string of a TAIL node
Hi Community,
I´m a fresh man in NR and need your help.
I try to use a string from my TAIL node and use this string to replace a placeholder in my JSON Object which I will use as a http POST request.
I stuck with the replacing. I have no idea how to replace the JSON value ("#????") with my value from my "tail-string" (e.g. DC12)
Thx !!
[{"id":"44f39358.4f8b4c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"b0be09cb.e33aa8","type":"http request","z":"44f39358.4f8b4c","name":"Agilox Workflow","method":"POST","ret":"obj","paytoqs":"ignore","url":"http://141.73.250.4:8100/workflow/0","tls":"","persist":false,"proxy":"","authType":"","x":560,"y":300,"wires":[["9c9bd940.eb1fa8","59e8e1ec.845ec"]]},{"id":"9c9bd940.eb1fa8","type":"debug","z":"44f39358.4f8b4c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":260,"wires":[]},{"id":"59e8e1ec.845ec","type":"file","z":"44f39358.4f8b4c","name":"Agilox Order Logfile","filename":"C:\\Users\\xxxx\\Desktop\\Agilox.txt","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":830,"y":320,"wires":[[]]},{"id":"da10ec19.d874a","type":"tail","z":"44f39358.4f8b4c","name":"agilox","filetype":"text","split":"[\\r]{0,1}\\n","filename":"C:\\\\Users\\\\xxx\\\\Desktop\\\\Node-Red Test\\\\Agilox.txt","inputs":0,"x":90,"y":400,"wires":[["648d22c8.cccd7c","cf308e72.2fb21"]]},{"id":"648d22c8.cccd7c","type":"debug","z":"44f39358.4f8b4c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":400,"wires":[]},{"id":"cf308e72.2fb21","type":"change","z":"44f39358.4f8b4c","name":"Destination zufügen","rules":[{"t":"set","p":"payload","pt":"msg","to":"{    \"SOURCE\": **#??????**?,    \"DESTINATION\": \"DC16\",    \"PRIORITY\": 50,    \"userdata\": {        \"host_orderid\": 3541387    }}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":300,"wires":[["b0be09cb.e33aa8"]]}]
Hi, in order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
sry, thank you for the hint
It is really difficult to understand what you are trying to achieve.
If you have a JS object, just use a change node to set msg.payload.SOURCE to whatever value you want.
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
You can also use JSONata in the change node as below
[{"id":"1549ec9d.6caf3b","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"75b850c4.fc461","type":"http request","z":"1549ec9d.6caf3b","name":"Agilox Workflow","method":"POST","ret":"obj","paytoqs":"ignore","url":"http://141.73.250.4:8100/workflow/0","tls":"","persist":false,"proxy":"","authType":"","x":560,"y":300,"wires":[["105dc6b1.05c161","f6f83eb6.6d26"]]},{"id":"105dc6b1.05c161","type":"debug","z":"1549ec9d.6caf3b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":260,"wires":[]},{"id":"f6f83eb6.6d26","type":"file","z":"1549ec9d.6caf3b","name":"Agilox Order Logfile","filename":"C:\\Users\\xxxx\\Desktop\\Agilox.txt","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":830,"y":320,"wires":[[]]},{"id":"7e67540c.e4db34","type":"tail","z":"1549ec9d.6caf3b","name":"agilox","filetype":"text","split":"[\\r]{0,1}\\n","filename":"C:\\\\Users\\\\xxx\\\\Desktop\\\\Node-Red Test\\\\Agilox.txt","inputs":0,"x":90,"y":400,"wires":[["2c3f3bb7.4322e4","b2f57bb2.f0c31"]]},{"id":"2c3f3bb7.4322e4","type":"debug","z":"1549ec9d.6caf3b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":400,"wires":[]},{"id":"b2f57bb2.f0c31","type":"change","z":"1549ec9d.6caf3b","name":"Destination zufügen","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"SOURCE\": payload,\t   \"DESTINATION\":\"DC16\",\t   \"PRIORITY\":50,\t   \"userdata\":{\"host_orderid\":3541387}\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":300,"wires":[["75b850c4.fc461"]]}]
Thanks Steve-Mci & E1cid !!
@E1cid: your solution works perfect !!
@Steve-Mcl: thanks for your patience and your hints!
Now I´ve unterstood the method of msg.payload !
